QUIC misconfigured and node status offline
Hello There,
Greetings!!
I am getting QUIC misconfigured error after completion of my setup. I have setup no-ip and also configured port forwarding rules(TCP & UDP) on my router. But don’t know what exactly the issue are. Here I have attached my screenshot. It also shows UPTIME but status shows offline.
Waiting for your positive reply.
Thanks.
do you have windows or linux? did you signed identity?
Ubuntu(Linux). Yes I have signed identity.
Then please check remaining points form this checklist:
@Alexey
I have checked the firewall and the port is not blocked.
When I run the docker command, I see 5 files, I have moved ca.key to secure location as per the documentation.
Please check your WAN IP on your router and compare it with IP on Open Port Check Tool - Test Port Forwarding on Your Router, if they don’t match, the port forwarding will not work.
Please also check your DDNS hostname (replace your.ddns.domain with your DDNS domain):
nslookup your.ddns.domain 8.8.8.8
It should return the same IP as WAN IP and IP from yougetsignal, if not - you need to check your DDNS updater (it’s better to configure your router to update DDNS if it’s supported rather than use an application).
@Alexey
Thank you for responding. I have verified and all 3 IPs are same.
Also I have configured router for DDNS.
Please compare the local IP of your PC with IP in the port forwarding rule on your router.
If they match too, then please show your port forwarding rules from the router and rules in your firewall (please note - you should not have any active outbound firewall rules).
Please also post the last 20 lines from your logs: How do I check my logs? | Storj Docs
Please do it between two new lines with three backticks:
log lines
did you checked with port open tool, does your ports are open from outside?
May be you are behind provider NAT?
@Vadim @Alexey
I had checked with port open tool and it shows closed. So I had contacted with my ISP regarding that and I am waiting for their reply on that.
Thanks.
@Alexey @Vadim
I had word with my ISP and they told me that they are not blocking any port. All port are open from their end.
Now I don’t know what exactly the issue is.
@Alexey @Vadim
Here are my logs:
docker logs --tail 20 storagenode
2022-03-25T15:58:53.730Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 5, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T15:58:53.760Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 9, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T15:59:03.856Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 7, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T15:59:30.441Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 6, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T15:59:31.107Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 8, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:00:23.284Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 7, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:00:29.831Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 8, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:01:39.633Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 9, "error": "ping satellite: check-in ratelimit: node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:01:48.072Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 8, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:02:45.020Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 9, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:03:01.396Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 11, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:03:16.006Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 10, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:03:56.901Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 9, "error": "ping satellite: check-in ratelimit: node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:05:45.211Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 11, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:06:16.217Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 10, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:07:21.874Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 10, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:08:33.758Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 10, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:11:54.745Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 11, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:15:08.908Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 11, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: quic connector failed: quic: timeout: no recent network activity; tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: quic connector failed: quic: timeout: no recent network activity; tcp connector failed: rpc: dial tcp 103.86.19.247:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-25T16:16:01.055Z	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 11, "error": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1LERtJcr94iWyZPgoTBmLFxNAMosaU9KyGzsBJNnENR8yNzMHY) at address aryaj.ddns.net:28967: rpc: tcp connector failed: rpc: dial tcp 103.86.19.247:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
What do you see in the WAN IP field on your router?
What IP do you see on Open Port Check Tool - Test Port Forwarding on Your Router?
what linux do you have, may be you have firewall on linux, some destributions have it by default
Also what router do you have, some routers, have bad portforwasr, starting to work some times after restart
@Vadim I am using ubuntu 18.04. ZTE F670L router. I have restarted router a few times as well.
@Alexey
On Open Port Check tool I am seeing
103.86.19.247
Are you referring to this attached WAN IP?
Yes. And it’s do not match the IP for your DDNS hostname.
What’s IP on yougetsignal?
If they are different - you behind the ISP’s NAT, in this case the port forwarding will not work.
@Alexey
IP on yougetsignal is
103.86.19.247
Can I make it work? or How do I make it work?
Do you have a second router in your network? If so, you should create port forwarding rules on the first router to the second router.
If you do not have the second router and this one is directly connected to your ISP, then you have a few options:
  1. Call to your ISP and ask for public IP, it could be dynamic, but must be a public (the WAN IP will match the IP on yougetsignal); you can say that you need an access to your security cam anywhere to do not explain Storj to ISP’s staff;
  2. Switch to ISP who offer a public IP;
  3. Use VPN services with port forwarding feature such as portmap.io, ngrok, PIA, PureVPN, AirVPN, etc.
can you try sudo ufw status in linux commnd to make sure firewall not working
