I am trying to host a node, but unfortunately the QUIC remains on misconfigured even though i have done the No-IP and port forward steps. I am aware of a single thing that might be an issue, and it’s the fact that the router (a TP-Link) isn’t allowing me to separate TCP and UDP (so i’m having both of them in a single rule). Rest is good. Does anyone of you have any idea on how to solve? Or it’s just to wait? Forcing a refresh is not changing stuff.
I can’t find any storj-related rule on Windows Firewall. What i think it might be the issue, is the fact i’m still under CG-NAT, hence this issue.
At the current time the node is actually working without issues, am i earning or am i disqualified? I will try to fix this issue with the help of my ISP as well by changing the IP as Dynamic Public IP.
Update for everyone: ISP solved the issue by placing a dynamic public IP address. Now QUIC is in “OK” status. I also added the rule in the firewall as it was still missing. Thanks!
