I have now implemented it like this and the dashboard is now back. That’s reassuring! Thank you.
But Quic still shows “Misconfigured”.
Actually, it can only be the router now. However, I already set everything there.
TCP and UDP port 28967 released
TCP is green…and open…just for completeness.
And…
docker ps -a
8b198***ac05 storjlabs/storagenode:latest “/entrypoint” 20 minutes ago Up 19 minutes 0.0.0.0:14002->14002/tcp, 0.0.0.0:28967->28967/tcp, 0.0.0.0:28967->28967/udp storagenode
If I’m using docker in qnap, and I run with the new command (which includes new ports compared to the old command), I get errors that the identify is incorrect. If I remove and run with the old command again, it works but i’m still misconfigured on QUIC. Any ideas how to upgrade an old setup to include the new port?
You should change only port settings in your command and do not touch mounting of the identity and storage.
