How is this measured?
Not only do I have both TCP and UDP forwarded, but UDP is being used:
[root@localhost ~]# tcpdump -i enp9s0 udp port 28967 -XAvvv &>/tmp/udp.dump
and then
[root@localhost ~]# grep -Po "(?<=\s)\S+(?=\.\d+\s\>)" /tmp/udp.dump | grep -v localhost | sort | uniq -c | sort -k1nr
19 277185.simplecloud.ru
8 us-central.meteoroid.dev.storj.io
[root@localhost ~]#
So why does it state misconfigured?
