Quick growth of piece_expiration.db
Hrm. Is it only the one instance of that error or is it recurring?
It is recurring over multiple logs.
Interesting. I wonder if something is trying to open a second handle to that db when it’s already open. Something must have a handle open to it somewhere.
Does anyone else have these errors? That would explain some excessive growth of the db file.
I can’t check my nodes, so don’t take my silence as a NO :). I believe @Ruskiem said something about locked db-es in other thread.
Perhaps it could be a lazy filewalker process? It’s a separate Storagenode instance
2023-12-23T03:07:19Z    WARN    retain  failed to delete piece  {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "YT4EZ34ZRG3V2DW7JFMOGWP7YGYUR6QS7QWVMDOHEYBX6QUUE5WA", "error": "pieces error: pieceexpirationdb:
database is locked", "errorVerbose": "pieces error: pieceexpirationdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceExpirationDB).Trash:112\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:403\n\tstorj.io/storj/storagenode/retain.(*Service)
.trash:364\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:341\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:221\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2023-12-23T13:02:59Z    WARN    retain  failed to delete piece  {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "ZW5JE4F5IRSPSUZQY7PDVYMS57OXMIMFHUWCL6VQ4PASHEXO7YEA", "error": "pieces error: pieceexpirationdb:
2023-12-23T13:03:10Z    WARN    retain  failed to delete piece  {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "ZW5JJITWFSJ3344EA6KB4KMKXZLEAER3QXJ5L6PIVLG4CRY2NJNQ", "error": "pieces error: pieceexpirationdb:
2023-12-23T13:03:20Z    WARN    retain  failed to delete piece  {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "ZW5JVD3G4WDX6MQ2URMAOWDLI5EVGGC4Y3RTJ7OV3ODXCX4RUNDQ", "error": "pieces error: pieceexpirationdb:
2023-12-23T13:03:33Z    WARN    retain  failed to delete piece  {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "ZW5JX4MRYGOXVSHNU6EC5IGP2DNWGHUW6FCLLLXH5LMBK5L6LBPQ", "error": "pieces error: pieceexpirationdb:
2023-12-24T07:49:11Z    ERROR   piecestore      upload failed   {"process": "storagenode", "Piece ID": "GD6NBZ5KONLZWAZOTV2WUR6I546WOITG3WM4YSR6TCMP25IWEBPQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "error": "pieceexpirationdb:
database is locked", "errorVerbose": "pieceexpirationdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceExpirationDB).SetExpiration:67\n\tstorj.io/storj/storagenode/pieces.(*Store).SetExpiration:587\n\tstorj.io/storj/storagenode/piecestore.(*End
point).Upload.func6:483\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:541\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/
common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 261632,
"Remote Address": "172.17.0.1:48520"}
2023-12-24T07:49:11Z    ERROR   piecestore      upload failed   {"process": "storagenode", "Piece ID": "FSS34SO6KZZLTFA4ZSRZUBELITHSHAE7L4VHFOAQCZN73KQCJTTA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "error": "pieceexpirationdb:
point).Upload.func6:483\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:516\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/
common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 11264, "Remote
Address": "172.17.0.1:48484"}
2023-12-25T02:17:48Z    ERROR   collector       unable to update piece info     {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "2XLSFR7RKZXCZZUBAATNNJRFNZG7DTSXQGKQ3UILLHTHO3AZ3FKQ", "error": "pieceexpirationdb:
database is locked", "errorVerbose": "pieceexpirationdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceExpirationDB).DeleteFailed:99\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteFailed:597\n\tstorj.io/storj/storagenode/collector.(*Servic
e).Collect:109\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tsto
rj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2023-12-25T02:17:48Z    ERROR   collector       unable to delete piece  {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "2XLSFR7RKZXCZZUBAATNNJRFNZG7DTSXQGKQ3UILLHTHO3AZ3FKQ", "error": "pieces error: database is
locked", "errorVerbose": "pieces error: database is locked\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteExpired:365\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:344\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagen
ode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Ru
2023-12-29T00:54:29Z    ERROR   piecestore      upload failed   {"process": "storagenode", "Piece ID": "HBJVKPMU7BK4EIEDSK3TUFT4VC5RAX6ULI6AXGUOY3MDKKADZ4IQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "error": "pieceexpirationdb:
common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 287232,
"Remote Address": "172.17.0.1:42876"}
More log entries if it helps.
seems you need to move databases to the SSD…
Also an usb flashdrive seems to work fine! I use this
[Samsung USB-Stick Typ-A BAR Plus (MUF-128BE4/APC), 128 GB]
You gave me an ideea… to use flash drives on my Synology’s for db-es. I think there was a discussion about this, and the conclusion was that they can’t handle the I/O; but if it works for you, maybe it’s a good solution.
Reexamining my db sizes on all nodes, I just realised that on the old nodes they are ~530MB, except one, which is ~330MB.
What is the difference between them? On this one, I ran the FW with lazy off. On the others, the lazy was on. So, it seems that the lazy fw has something to do with the piece_expiration.db getting huge.
You could run the SQL commands over the db to see what it holds. Copy the db file to another location then execute SQL commands on it.
Just take a decent one. (i chose the samsung because of the 5y warranty and i did read a test)
i reformated them to 4k ntfs.(i use windows)
maybe the realy old ones? with fat32 or exfat?
but an CMR drive can? doubt.
in iops (at 4k cluster), it has around 3-6k wich is 8 to 20 times of an cmr disk.
Also dbs are non critical. so reliability does not realy matter
What commands? I’m not familiar with SQL queries.
First SQL query :point_down:
SELECT
 strftime('%Y', piece_expiration) AS year,
 COUNT (piece_id) AS num_piece_ids
FROM
   piece_expirations
GROUP BY
  year
ORDER BY
   year;
Second SQL query :point_down:
SELECT
    satellite_id, piece_id, piece_expiration, deletion_failed_at
FROM
    piece_expirations
WHERE
    piece_expiration < '2023-01-01 00:00:00'
ORDER BY
    piece_expiration;
You can get the binaries from Downloads - DB Browser for SQLite
I did this queries on one of my nodes, 14 months old, with piece_expiration.db of 530MiB and the Vacuum.
Results:
  • the vacuum shrinked all 14 db-es with 9% per total, so the piece_expiration.db is still huge.
  • firt query gave me:
    2022 46
    2023 420
    2024 2272544
    9999 26369
  • second query dosen’t show anything in the ā€œreason for failed deletesā€ column, just NULL.
    I verified for < 2023, <2024, <2025.
When I did the vaccuming I also got like 10% only, had also a higher expectation.
Vaccum is only removing empty space. It wont shrink if the size is because there is data there.
After a vacuum, that I’ve never ran before, the biggest db file (piece_expirations) went from 1.7G to 361M !
Should it be run regulary ?
now we habe 12GB piece_expiration dbs. on 6 TB data, i find it suspicious, we moved house, so had a downtime of 24h, lost a lot of data (~4TB got deleted or trashed), but the dbs stay the same size…
