Hello together,
only some months ago I started a new node and it has already ~200 MB of the piece_expiration.db. Can somebody explain the high growth rate and how to shrink it? The filewalker is not active.
Thanks and kind regards,
Well, without Filewalker running to purge expired segments, you are going to build them up (And not get paid for having them) which subsequently increases the database size
Considering above data, does it mean I have 435 pieces that got left behind from the year 2022 ?
I got also way older nodes who have like 60 MB. Don’t know if it is filewalker-related.
Fair enough. I don’t know off the top of my head the database retention rules. Will ask an engineer.
well ,my filwalker is runnig for sure, and i have same 250MB .db… at 3TB node data
maybe clients add data for only a short time?
Try vacuuming it.
When the data-bases are moved to a SSD, then the problem is solved. Unfortunately it also happends to a single node on a 20 TB CMR Enterprise HDD.
@Alexey your opinion on this please.
I have no idea, I usually respond only when I think that I know the answer.
I appreciate and admire that in you hence the title of Awesome ![]()
I thought it’s only me, and I was going to ignore it, but I also have that db way too big. I remember I checked all dbs a few monyhs ago and the biggest was the bandwidth. Now the piece…db is the biggest. I’ll edit with all the sizes from my nodes in an hours or so. So this si a recent thing. The FW was run on all nodes last week.
How can I “vacuum” them? Is it dangerous? Do I have to stop the nodes?
You can vacuum them the usual way for SQLite:
However
I think you should not fix what’s not broken.
I don’t know, but something fishy is happening. The piece_expiration.db is growing FAST!
These are all my nodes; take note that those small ones are started on 30-31 december, so I don’t even know if they are fully vetted, and have huge db for their age, too. The FW was run.
Synology’s, Exos, ext4, no ssd.
Node: space occupied / piece_expiration.db
node11: 12.3TB / 527MiB
node12: 431GB / 77MiB
node21: 14.3TB / 512MiB
node22: 426GB / 77MiB
node31: 6.8TB / 160MiB
node32: 6.8TB / 255MiB
node41: 11.1TB / 522MiB
node42: 425GB / 78MiB
node51: 12.8TB / 530MiB
node52: 433GB / 78MiB
node61: 14.4TB / 418MiB
node71: 14.5TB / 324MiB
node72: 654GB / 105MiB
node81: 14.4TB / 516MiB
node82: 427GB / 78MiB
I have also several 400-500 MB piece_expiration DBs. Like I said the only solution was to move the DBs to a SSD and to change the --mount order, with this guide:
Now the dashboard and the STORJ-Exporterlogs are fine after the DB-moving.
It certainly seems like something is wrong. The collector service on your node should be continually trying to get rid of any entries older than the current time. My only theory is that it is experiencing some error trying to delete those files. If that’s the case, it would keep those entries around so it could try again later. Do you have any errors in the log relating to a service called “collector”?
Another thing to check would be whether the deletion_failed_at column is set for those entries:
SELECT
satellite_id, piece_id, piece_expiration, deletion_failed_at
FROM
piece_expirations
WHERE
piece_expiration < '2023-01-01 00:00:00';
ORDER BY
piece_expiration;
that would mark the last time the node failed in trying to delete those pieces. If it’s blank, something altogether different is going on.
The semi colon terminated the where clause so I edited it ![]()
I will work on that and edit this post.
Edit:
2023-12-25T02:17:48Z ERROR collector unable to update piece info {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "2XLSFR7RKZXCZZUBAATNNJRFNZG7DTSXQGKQ3UILLHTHO3AZ3FKQ", "error": "pieceexpirationdb:
database is locked", "errorVerbose": "pieceexpirationdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceExpirationDB).DeleteFailed:99\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteFailed:597\n\tstorj.io/storj/storagenode/collector.(*Servic
e).Collect:109\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tsto
rj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2023-12-25T02:17:48Z ERROR collector unable to delete piece {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "2XLSFR7RKZXCZZUBAATNNJRFNZG7DTSXQGKQ3UILLHTHO3AZ3FKQ", "error": "pieces error: database is
locked", "errorVerbose": "pieces error: database is locked\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteExpired:365\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:344\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagen
ode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Ru
