Quickly deployed a new node on same ip:port
Yesterday I had a filesystem crash on my node. I quickly deleted everything and deployed a new node with a new identity, used same external ip:port. New node says offline and QUIC misconfigured, although it is perfectly visible from the outside.
Now I have to wait until all satellites expire my old node to accept the new one, or what? Is there a way to speed up this?
The end of the log is:
2024-06-05T14:50:48+03:00 ERROR nodestats:cache Get disk space usage query failed {error: nodestats: EOF; nodestats: EOF; nodestats: EOF; nodestats: EOF, errorVerbose: group:\n— nodestats: EOF\n\tstorj.io/storj/storagenode/nodestats.(*Service).GetDailyStorageUsage:123\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheSpaceUsage.func1:216\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:306\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheSpaceUsage:215\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func3:138\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n— nodestats: EOF\n\tstorj.io/storj/storagenode/nodestats.(*Service).GetDailyStorageUsage:123\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheSpaceUsage.func1:216\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:306\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheSpaceUsage:215\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func3:138\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n— nodestats: EOF\n\tstorj.io/storj/storagenode/nodestats.(*Service).GetDailyStorageUsage:123\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheSpaceUsage.func1:216\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:306\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheSpaceUsage:215\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func3:138\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n— nodestats: EOF\n\tstorj.io/storj/storagenode/nodestats.(*Service).GetDailyStorageUsage:123\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheSpaceUsage.func1:216\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:306\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheSpaceUsage:215\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func3:138\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}
2024-06-05T14:50:48+03:00 ERROR nodestats:cache payouts err {satellite: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE}
2024-06-05T14:50:49+03:00 ERROR nodestats:cache payouts err {satellite: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6}
2024-06-05T14:50:49+03:00 ERROR nodestats:cache payouts err {satellite: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S}
2024-06-05T14:50:49+03:00 ERROR nodestats:cache payouts err {satellite: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs}
2024-06-05T14:50:49+03:00 ERROR nodestats:cache Get held amount query failed {error: payouts service: node not found: 12Pop9nxiU8RrkkasFANNtSS7JZZmKYhRxXvTXbW2jBZc3aKT5V; payouts service: node not found: 12Pop9nxiU8RrkkasFANNtSS7JZZmKYhRxXvTXbW2jBZc3aKT5V; payouts service: node not found: 12Pop9nxiU8RrkkasFANNtSS7JZZmKYhRxXvTXbW2jBZc3aKT5V; payouts service: node not found: 12Pop9nxiU8RrkkasFANNtSS7JZZmKYhRxXvTXbW2jBZc3aKT5V, errorVerbose: group:\n— payouts service: node not found: 12Pop9nxiU8RrkkasFANNtSS7JZZmKYhRxXvTXbW2jBZc3aKT5V\n\tstorj.io/storj/storagenode/payouts.(*Endpoint).GetPaystub:73\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheHeldAmount.func1:249\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:306\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheHeldAmount:241\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func3:143\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n— payouts service: node not found: 12Pop9nxiU8RrkkasFANNtSS7JZZmKYhRxXvTXbW2jBZc3aKT5V\n\tstorj.io/storj/storagenode/payouts.(*Endpoint).GetPaystub:73\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheHeldAmount.func1:249\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:306\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheHeldAmount:241\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func3:143\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n— payouts service: node not found: 12Pop9nxiU8RrkkasFANNtSS7JZZmKYhRxXvTXbW2jBZc3aKT5V\n\tstorj.io/storj/storagenode/payouts.(*Endpoint).GetPaystub:73\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheHeldAmount.func1:249\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:306\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheHeldAmount:241\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func3:143\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n— payouts service: node not found: 12Pop9nxiU8RrkkasFANNtSS7JZZmKYhRxXvTXbW2jBZc3aKT5V\n\tstorj.io/storj/storagenode/payouts.(*Endpoint).GetPaystub:73\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheHeldAmount.func1:249\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:306\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheHeldAmount:241\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func3:143\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}
2024-06-05T14:52:04+03:00 ERROR contact:service ping satellite failed {Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, attempts: 9, error: ping satellite: check-in ratelimit: node rate limited by id, errorVerbose: ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:203\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}
2024-06-05T14:52:07+03:00 ERROR contact:service ping satellite failed {Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, attempts: 9, error: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert, errorVerbose: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:209\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}
2024-06-05T14:52:10+03:00 ERROR contact:service ping satellite failed {Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, attempts: 9, error: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert, errorVerbose: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:209\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}
2024-06-05T14:52:12+03:00 ERROR contact:service ping satellite failed {Satellite ID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE, attempts: 9, error: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert, errorVerbose: ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:209\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}
All fine with these modern projects, but ANY problem that you run into is never seen before and nobody can help, so you can only ditch the whole idea.
Did you authorize the new identity after you created it?
Oh! Many thanks!!! Forgot that!
Perhaps rethink this post… :wink:
