Hello,
I’d like to build a pure java library to interact with the STORJ storage.
Is the RCP documentation publicly available?
I could not find anything more than bindings to the C/go version of uplink…
Thanks in advance,
Stefano
Hello,
Thanks in advance,
Stefano
Have you taken a look at this ![]()
Not pure Java.
AFAIK there is no in-depth documentation so far, last time I asked about it, I got this answer: Storj protocol (from the customer's point of view) - #2 by thepaul
Ah, thanks. That answer is quite informative; maybe the easiest path for me is to go through the S3 gateway and use an S3 SDK.
No, the RAW API documentation for Java is not publicly available. However,you can use the C/Go binding of uplink in Java by leveraging Java Native interface.
