Using TrueNAS Cloud Sync (rclone) to upload to Storj via the S3 MT gateway. I am able to list buckets and items in my buckets, but when I start an upload task, I get a 403 Access Denied error when uploading.
I have double checked my Access Keys and credentials, and all seems okay. Here’s my config:
But more like it’s not related to the rclone options, perhaps your access grant has limitations.
Please try to re-create the access grant and make sure that you did not forbid the write operations, register this access grant on GatewayMT and use a new S3-compatible credentials in the rclone config (you can create a new remote instead of replace).
