Re-use identity key of gracefully exited node
Hi,
after complete the gracefully exit of a node due to HDD issue, is it possibile use again the identity key for create a new node ?
thx
No. You need to delete this identity, generate a new one, sign it with a new authorization token and start with a clean storage.
