Hello.
I have a second node in a data center with 1gbps in out flat unmetered…
First was offline for my necessity , now after 1 month online without receive any data, after the kernel upgrade of the proxmox virtualization enviroment… the node is always offline…
ERROR version Failed to do periodic version check: version control client error: Get https://version.storj.io: dial tcp: lookup version.storj.io on 1.1.1.1:53: read udp 172.17.0.3:58843->1.1.1.1:53: i/o timeout
root@storj2:~# reboot
Failed to connect to bus: Connection refused
Failed to open initctl fifo: No such device or address
Failed to talk to init daemon
538959cf6541 storjlabs/storagenode:beta “/entrypoint” 7 days ago Up 2 minutes 0.0.0.0:14002->14002/tcp, 0.0.0.0:28967->28967/tcp storagenode
4ee7a96d48ac storjlabs/watchtower:latest “/watchtower storage…” 7 days ago Up 2 minutes watchtower
There is no data.
I was setup the server the first time as test. After was off one month for my needs… after starting the virtual machine I was not receiving data because the previous down…
Now was near to 25 days of uptime without receiving data.
I use storj only in server machines, the desks are under heavy load for other purposes… Windows virtual machine use too much resources.
A Linux container, one cpu core, 256mb ram. Windows 4 cores, 4gb ram at least!!!
