Regarding GatewayST Setup
Hi,
I’m migrating my pixelfed instance to a new server. As a part of the migration process I’m setting up GatewayST on my new server.
I generated an api key and followed exact same steps mentioned in the docs.
Gateway is running without any issues.
But the problem occured when I tried to created a systemd service and run the gateway in website mode.
Here’s my config:
Here’s what I get after “systemctl status gateway”:
And.
I was using the default access found in the config.yaml …
Regarding access grants…
Can I use my own access grant (generated by me) in the config.yaml ?
Or I have to generate the key from satellite UI ?
I dont understand this part.
Thanks :blush:
You need to setup your gateway anyway.
For example, like this:
$ gateway setup --non-interactive --access 1cCYertoijhgoiogtjgfhtrhmrohjbokgfmnvbortmbrtkhjriotobmjiotyhbt....
After that you can run it:
$ gateway run
and you will see the access key and secret key in the log output.
For root, you just need to do that as root.
The needed file is ~/.local/share/storj/gateway/config.yaml (for root it will be /root/.local/share/storj/gateway/config.yaml), which contain
# the serialized access, or name of the access to use
access: 1cCYertoijhgoiogtjgfhtrhmrohjbokgfmnvbortmbrtkhjriotobmjiotyhbt....
If you do not plan to change the access grant too often, you may just setup it once and hardcode resulted S3 creds in your app.
Is there any problem with the interactive setup ? I followed that !
Do I need to revert back ?
I’m not seeing any config file here …
Am I supposed to use the access key from my previous setup ?
I have backed up my previous access grant that was generated while setting up GatewayST (Interactive)
You may reuse it of course, just run a setup as root (or copy your config to the root home folder, or provide a path to the config file in the gateway run command with --config-dir option).
Just gateway run uses parameters from config.yaml and seems ignore your --access option…
Got it ! Created a new access grant from satellite dashboard and ran gateway setup as root user (sudo). Now I can see the config file in both location.
By the way, I see telemetry is enabled. What information does it collect ? How can I disable telemetry?
It collect the usage statistics (not personalized), you may disable it with option tracing.enabled: false in your config.yaml (root one, if you run it as root), or with an argument --tracing.enabled=false in your gateway run command.
Is the first one a error message ?
no. More like a warning - usually you should not run anything as root, it’s not safe.
It’s better to use a special limited user for that, especially when the service is not require any root access (like in this case).
But if i dont run gateway as root. I get insecure-dev-key error
Because you need to have config.yaml for this user :slight_smile:
Got it … There was a config file. It was created previously. I’m just gonna update the access key. Wont it work ?
I updated config.yaml for that user. But still getting that error. I think i have to run as root user (using sudo )
It will work even if you just copy the config.yaml file (just apply needed permissions).
This is not possible, if you did it correctly and this user has an access to this file, remember - it’s looking for ~/.local/share/storj/gateway/config.yaml
So, if the user is USER, the path would be /home/USER/.local/share/storj/gateway/config.yaml
However, if you use sudo, it will looking for config for the root, i.e. /root/.local/share/storj/gateway/config.yaml
You can see, what is home dir for the used user:
sudo -iu USER echo "$HOME"
Everything seems to be okay :+1:… Dunno what went wrong :confused:
Is this okay ?
I think yes. Especially if it’s running :slight_smile:
