Hi, i think the max concurent request are not in use any more but i get
2019-12-13T03:33:16.620Z e[31mERRORe[0m piecestore upload rejected, too many requests {"live requests": 9}
2019-12-13T03:35:06.961Z e[31mERRORe[0m piecestore upload rejected, too many requests {"live requests": 8}
this are the only rejected in my log.
in my config.yml i put a # in front of it and done a restart. This have i done some updates earlyer.
# how frequently bandwidth usage rollups are calculated
# bandwidth.interval: 1h0m0s
# how frequently expired pieces are collected
# collector.interval: 1h0m0s
# use color in user interface
# color: false
# server address of the api gateway and frontend app
console.address: :14002
# path to static resources
# console.static-dir: ""
# Maximum Database Connection Lifetime, -1ns means the stdlib default
# db.conn_max_lifetime: -1ns
# Maximum Amount of Idle Database connections, -1 means the stdlib default
# db.max_idle_conns: 20
# Maximum Amount of Open Database connections, -1 means the stdlib default
# db.max_open_conns: 25
# address to listen on for debug endpoints
debug.addr: :7777
# If set, a path to write a process trace SVG to
# debug.trace-out: ""
# open config in default editor
# edit-conf: false
# help for setup
# help: false
# path to the certificate chain for this identity
identity.cert-path: identity/identity.cert
# path to the private key for this identity
identity.key-path: identity/identity.key
# alpha is a system wide concurrency parameter
# kademlia.alpha: 5
# the Kademlia node to bootstrap against
# kademlia.bootstrap-addr: bootstrap.storj.io:8888
# the base interval to wait when retrying bootstrap
# kademlia.bootstrap-backoff-base: 1s
# the maximum amount of time to wait when retrying bootstrap
# kademlia.bootstrap-backoff-max: 30s
# size of each Kademlia bucket
# kademlia.bucket-size: 20
# the path for storage node db services to be created on
# kademlia.db-path: config/kademlia
# the public address of the Kademlia node, useful for nodes behind NAT
kademlia.external-address: ""
# operator email address
kademlia.operator.email: ""
# operator wallet address
kademlia.operator.wallet: ""
# size of Kademlia replacement cache
# kademlia.replacement-cache-size: 5
# if true, log function filename and line number
# log.caller: false
# if true, set logging to development mode
# log.development: false
# configures log encoding. can either be 'console' or 'json'
# log.encoding: console
# the minimum log level to log
log.level: debug
# can be stdout, stderr, or a filename
# log.output: stderr
log.output: "/app/config/node.log"
# if true, log stack traces
# log.stack: false
# address to send telemetry to
# metrics.addr: collectora.storj.io:9000
# application name for telemetry identification
# metrics.app: storagenode
# application suffix
# metrics.app-suffix: -release
# instance id prefix
# metrics.instance-prefix: ""
# how frequently to send up telemetry
# metrics.interval: 1m0s
# path to log for oom notices
# monkit.hw.oomlog: /var/log/kern.log
# public address to listen on
server.address: :28967
# log all GRPC traffic to zap logger
server.debug-log-traffic: false
# if true, client leaves may contain the most recent certificate revocation for the current certificate
# server.extensions.revocation: true
# if true, client leaves must contain a valid "signed certificate extension" (NB: verified against certs in the peer ca whitelist; i.e. if true, a whitelist must be provided)
# server.extensions.whitelist-signed-leaf: false
# path to the CA cert whitelist (peer identities must be signed by one these to be verified). this will override the default peer whitelist
# server.peer-ca-whitelist-path: ""
# identity version(s) the server will be allowed to talk to
# server.peer-id-versions: latest
# private address to listen on
server.private-address: 127.0.0.1:7778
# url for revocation database (e.g. bolt://some.db OR redis://127.0.0.1:6378?db=2&password=abc123)
# server.revocation-dburl: bolt://config/revocations.db
# if true, uses peer ca whitelist checking
# server.use-peer-ca-whitelist: true
# total allocated bandwidth in bytes
storage.allocated-bandwidth: 2.0 TB
# total allocated disk space in bytes
storage.allocated-disk-space: 1.0 TB
# how frequently Kademlia bucket should be refreshed with node stats
# storage.k-bucket-refresh-interval: 1h0m0s
# path to store data in
# storage.path: config/storage
# a comma-separated list of approved satellite node urls
# storage.whitelisted-satellites: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S@mars.tardigrade.io:7777,118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW@satellite.stefan-benten.de:7777,121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6@saturn.tardigrade.io:7777,12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs@jupiter.tardigrade.io:7777
# how soon before expiration date should things be considered expired
# storage2.expiration-grace-period: 48h0m0s
# how many concurrent requests are allowed, before uploads are rejected.
# storage2.max-concurrent-requests: 6
# storage2.monitor.interval: 1h0m0s
# how much bandwidth a node at minimum has to advertise
# storage2.monitor.minimum-bandwidth: 500.0 GB
# how much disk space a node at minimum has to advertise
# storage2.monitor.minimum-disk-space: 500.0 GB
# how long after OrderLimit creation date are OrderLimits no longer accepted
# storage2.order-limit-grace-period: 1h0m0s
# allows configuration to enable, disable, or test retain requests from the satellite. Options: (disabled/enabled/debug)
# storage2.retain-status: disabled
# allows for small differences in the satellite and storagenode clocks
# storage2.retain-time-buffer: 1h0m0s
# duration between sending
# storage2.sender.interval: 1h0m0s
# timeout for sending
# storage2.sender.timeout: 1h0m0s
# Interval to check the version
# version.check-interval: 15m0s
# Request timeout for version checks
# version.request-timeout: 1m0s
# server address to check its version against
# version.server-address: https://version.alpha.storj.io
# interval between voucher service iterations
# vouchers.interval: 168h0m0s
#storage2.max-concurrent-requests: 20
startparameter + watchtower:
docker run -d --restart unless-stopped \
-p 28967:28967 \
-p 14002:14002 \
-p 7777:7777 \
-e WALLET="0x120B3d8BC249a2c82D890c228*****" \
-e EMAIL="******" \
-e ADDRESS="******:28967" \
-e BANDWIDTH="10TB" \
-e STORAGE="7TB" \
--mount type=bind,source="/opt/storj/identity",destination=/app/identity \
--mount type=bind,source="/opt/storj/data",destination=/app/config \
--name storagenode storjlabs/storagenode:beta
4vcpu 4GbRam
Debian10
docker
hdd direct connect sata
should i write “storage2.max-concurrent-requests” back to config?
node runs fine! only info about the rejected.
