Release preparation v1.136
I did all migrations with memtbl but a few days ago I switched to hashtbl. I don’t know if conversion is finished… :thinking:
It should switch with the nearest compaction.
thank you. now i got error in CMD
runtime: VirtualAlloc of 1007616 bytes failed with errno=1455
fatal error: out of memory
looks like nodes have some max that they can use interesting how can i fix it
at same time half of the ram is free
Also i have some stack info if it will help
I want to confirm - is it a hashstore or piecestore node?
it is Hashstore without memtbl, mostly converted.
Thank you! Shared with the team. As you may know, we do not have Windows nodes on Storj Select.
if you need something to help you just ask.
I do not have anything in my mind, but maybe our engineers may come to you to ask some information.
I found some interesting info, why node reserves gigabytes of memory?
it looks like every node, do it.
I also checked, other server, same thing, it reserves 4gb for something.
it show like thread Envirement block
@littleskunk may be you have some ideas why node reserves so much RAM? non memtbl used here, but it reserves 4gb of ram and not using it even
interesting that i checkt memory consumption with activated memtbl in Enviramental variable and where it not activated, momory consuption is the same.
