Reputation on second storagenode on different IP space?
I’ve built some reputation on my first storagenode over the last 4 months. I now wish to register a second storagenode on a different public IP using the same email address as the first.
Will the 2nd storagenode already have some reputation by virtue of the same email address? Or will reputation on the 2nd storagenode have to be built from scratch?
Each sign up is a new node so every new node has to create rep nothing is shared between. You can use the same email but there not connected in anyway.
you shold make new identity and sign it with new code. email can be same.
Yes, that’s what I did.
