Hello there!
I used a 3 TB Drive to provide that to Storj.
So about two weeks ago my drive crashed and i lost all Data
So i have baught a new 3 TB drive and set all up to Restart with Storj.
So i have a node ID and i removed the node from Docker and put into the docker run command my new drive loc.
At first every thing looks normal and Started Up look expected, soon i got a message that i were disqualified from Saltlake Sat.
So i hoped that this would be the only Sat. where i don´t get Data from but it came how it must came now i am disqual. from every Sat. expect from europe-nord Sat.
So i found out that when a audit fails mutch times or mutch Data get lost you get disqual.
So in my case i don´t have any chance to reach the data because the old Drive is dead.
Now my question:
If i start the node and make a gracefull exit (ok i will lose about 75 $ but better than not having a node run) can i than use the same node ID to restart by zero? Or how can i get to normal Work?
Please help me because i dont know.
Sorry for my bad english
