I want to configure the retain.concurrency:1 parameter to reduce disk load during garbage collection. What negative consequences can this have?
Non. I am running it like this all the time. My question is more the other way around. Why don’t we make 1 concurrent retain the new default?
what does this command do and why do you need it?
What is the default if this parameter is not set?
storagenode run --help
will print out all default values
