S3 gateway multipart upload with presigned urls javascript
Dear community,
We are building a webapp utilizing storj and we currently have problems with multipart uploads and presigned urls on the s3 gateway.
Especially, we are getting back a malformed response from the uploadPart property (Class: AWS.S3 — AWS SDK for JavaScript).
The response is:
The problem with that response is that it doesn’t return an ETag, from which we can then complete the multipart upload.
I suspect it has something to do with cors. We are trying to interact with the gateway from our localhost dev environment.
Any help would be greatly appreciated.
Hi @3eeaeb9ae56916c4c0be
Could you provide a JS snippet of all the steps that you are doing?
We’d like to see how you’re creating the pre-signed URLs, creating the multipart upload, and after how after you upload parts using them.
Thank you.
Sure. I am using sveltekit…
Client side:
export async function getStorjSignedUrl(path: string, filename: string) {
    const requestOptions = {
        method: 'GET',
        redirect: 'follow' as RequestRedirect
    try {
        const response = await fetch(`http://localhost:5173/api/storage/storj-signed-url?path=${path}&filename=${filename}`, requestOptions)
        return await response.json()
    } catch (error) {
        console.log('error', error)
export async function uploadFileStorj(readableStream: ReadableStream<Uint8Array>, filename: string, path: string) {
    //assume that filename & path are free (this should be checked in frontend)
    const createMPRequestOptions = {
        method: 'GET',
    try {
        //create multipart upload
        const createMPResponse = await fetch(`http://localhost:5173/api/storage/storj-create-multipart-upload?path=${path}d&filename=${filename}`, createMPRequestOptions)
        const {UploadId} = await createMPResponse.json()
        console.log('upload id', UploadId)
        //get signed urls for every part of the incoming stream
        //then use the signedurls to start the upload
        let partNumber = 1
        const uploadPromises = []
        for await (const iterator of readableStream as ReadableStreamType<Uint8Array>) {
            const getSignedUrlRequestOptions = {
                method: 'GET',
            const getSignedUrlResponse = await fetch(`http://localhost:5173/api/storage/storj-signed-url?path=${path}d&filename=${filename}&partnumber=${partNumber}&uploadid=${UploadId}`, getSignedUrlRequestOptions)
            const signedUrl = await getSignedUrlResponse.text()
            console.log(partNumber)
            console.log('signed url', signedUrl)
            //upload every part of the incoming stream
            const uploadPartRequestOptions = {
                method: 'PUT',
                body: iterator,
            const res = fetch(signedUrl, uploadPartRequestOptions)
            console.log(await res)
            uploadPromises.push(fetch(signedUrl, uploadPartRequestOptions))
            partNumber++
        const resUploadParts = await Promise.all(uploadPromises.map(async (item) => {
            const response = await item
            console.log(response.body)
            return response.json()
        console.log("result upload parts", resUploadParts)
        //complete multipart upload
        const completeUploadParams = {
            Bucket: "examplebucket",
            Key: "bigobject",
            MultipartUpload: {
             Parts: [
               ETag: "\"d8c2eafd90c266e19ab9dcacc479f8af\"",
               PartNumber: 1
               PartNumber: 2
            UploadId: "7YPBOJuoFiQ9cz4P3Pe6FIZwO4f7wN93uHsNBEw97pl5eNwzExg0LAT2dUN91cOmrEQHDsP3WA60CEg--"
    } catch (error) {
API endpoint http://localhost:5173/api/storage/storj-signed-url:
import type { RequestHandler } from "@sveltejs/kit";
import { generatePath } from "$lib/utils";
import { getSignedUrl } from "@aws-sdk/s3-request-presigner";
import { UploadPartCommand } from "@aws-sdk/client-s3";
import { S3 } from "@aws-sdk/client-s3";
import { STORJ_ACCESS_KEY, STORJ_SECRET_ACCESS_KEY, STORJ_ENDPOINT, STORJ_REGION, STORJ_BUCKET } from '$env/static/private';
export const s3 = new S3({
    credentials: {
        accessKeyId: STORJ_ACCESS_KEY,
        secretAccessKey: STORJ_SECRET_ACCESS_KEY
    endpoint: STORJ_ENDPOINT,
    forcePathStyle: true,
    region: STORJ_REGION
export const GET: RequestHandler = (async ({ url }) => {
    const path = url.searchParams.get('path') ?? generatePath()
    const filename = url.searchParams.get('filename') ?? generatePath()
    const partNumber = Number(url.searchParams.get('partnumber'))
    const uploadId = url.searchParams.get('uploadid')
    console.log(uploadId)
    if(uploadId === null) {
        console.log(new Error("no upload id or partnumber specified"))
        return new Response()
    } else {
        const bucketParams = {
            Bucket: STORJ_BUCKET,
            Key: `${path}/${filename}`,
            PartNumber: partNumber,
            UploadId: uploadId
        const command = new UploadPartCommand(bucketParams)
        const signedUrl = await getSignedUrl(s3, command)
        return new Response(signedUrl)
API endpoint http://localhost:5173/api/storage/storj-create-multipart-upload:
import { json, type RequestHandler } from "@sveltejs/kit";
    credentials: {
    let res
    try {
        res = await s3.createMultipartUpload(bucketParams)
    } catch (error) {
        console.log(error)
    return json(res)
I’m a bit confused and I have to say that I don’t have that much experience in this area, but if you are using the pre-signed URL for uploading parts I don’t understand why do you have to call uploadPart?
Oh, well I have to supply a command to getSignedUrl… and UploadPartCommand is the correct one I would say. I later do a simple PUT to the signed url.
Also seems to be correct as written in stack overflow node.js - migrate multipart upload with presigned urls from aws javascript sdk v2 to v3 - Stack Overflow
According to UploadPart - Amazon Simple Storage Service the etag is part of the headers in the response.
Also it seems you’re still using v2 with s3.createMultipartUpload(bucketParams). In AWS SDK v3 you’ll do:
const command = new CreateMultipartUploadCommand(bucketParams);
const resp = await s3Client.send(command);
Here’s a express server example
var express = require("express");
var router = express.Router();
var {
  S3Client,
  CreateMultipartUploadCommand,
  UploadPartCommand,
} = require("@aws-sdk/client-s3");
const { getSignedUrl } = require("@aws-sdk/s3-request-presigner");
const s3Client = new S3Client({
  credentials: {
    accessKeyId: process.env.ACCESS_KEY,
    secretAccessKey: process.env.SECRET_KEY,
  region: "global",
  endpoint: "https://gateway.storjshare.io",
router.post("/presign-multipart", async function (req, res, next) {
  try {
      Bucket: "demo-bucket",
      Key: `${req.body.path}/${req.body.filename}`,
      PartNumber: req.body.partNumber,
      UploadId: req.body.uploadId,
    const command = new UploadPartCommand(bucketParams);
    const signedUrl = await getSignedUrl(s3Client, command, {
      expiresIn: 3600,
    res.json({ url: signedUrl });
  } catch (err) {
    console.error(err);
router.post("/create-multipart", async function (req, res, next) {
  try {
    res.json(resp);
  } catch (err) {
    console.error(err);
Calling the endpoints on the server would look something like this:
#!/bin/bash
UPLOAD_ID=$(curl http://localhost:3001/create-multipart -d 'path=test' -d 'filename=file' | jq -r .UploadId)
# echo $UPLOAD_ID
URL=$(curl http://localhost:3001/presign-multipart -d 'path=test' -d 'filename=file' -d 'partNumber=1' -d "uploadId=$UPLOAD_ID" | jq -r .url)
# echo $URL
curl -v -X PUT --data-binary @part1.txt $URL
And the response of that last curl is (notice the Etag as part of the header):
< HTTP/2 200
< accept-ranges: bytes
< content-security-policy: block-all-mixed-content
< date: Thu, 05 Jan 2023 23:08:07 GMT
< etag: "871c68189b326a94de95e219f660448e"
< server: MinIO
< vary: Origin
< x-amz-request-id: 17378C55F9E21B04
< x-xss-protection: 1; mode=block
< content-length: 0
@danw Thanks for your detailed answer!
I can see that the last curl is the one to upload part @part.txt to the server - could you give me an example on how to actually upload all parts from a js readablestream to the server?
I adjusted the API endpoint http://localhost:5173/api/storage/storj-create-multipart-upload:
import { S3, CreateMultipartUploadCommand } from "@aws-sdk/client-s3";
    credentials: {
    let res
    try {
        res = await s3.send(command)
    } catch (error) {
        console.log(error)
    return json(res)
Still the same response…
As the response status is 200, but the type is CORS, could it be that storj doesn’t include “ETag” in the “CORS-safelisted response-header name” (https://fetch.spec.whatwg.org/#cors-safelisted-response-header-name).
Here is a stack overflow thread showing how this would be done on the server side: json - How to fix this error I’m getting from Amazon s3: ETagMissing: No access to ETag property on response. Check CORS configuration to expose ETag header - Stack Overflow
Can you paste the output of the etag header?
console.log("etag", resp.headers.get("etag"));
I’m not having any trouble getting the etag, so I’m not sure what’s different on your end.
I do see the preflight CORS request, but it’s followed by the upload request (I don’t do anything special here, see code below).
From the upload request I can see the etag in the response in the console. You’ll also notice access-control-expore-headers includes Etag, so the s3 gateway seems to be configured correctly.
Not entirely a js readablestream example, but it’s uploading a file in javascript in the browser. It’s more or less the curl example above converted to javascript.
import "./App.css";
import { useState } from "react";
function App() {
  const [loading, setLoading] = useState(null);
  const onSubmit = async (event) => {
    event.preventDefault();
    setLoading(true);
    try {
      let file = event.target[0].files[0];
      let url = `http://localhost:3001/create-multipart`;
      let params = new URLSearchParams({
        filename: file.name,
        path: "test",
      let resp = await fetch(url, {
        method: "POST",
        body: params,
      let createMultipartResp = await resp.json();
      console.log("create-multipart resp", createMultipartResp);
      url = `http://localhost:3001/presign-multipart`;
        path: "test",
        uploadId: createMultipartResp.UploadId,
        partNumber: 1,
        method: "POST",
        body: params,
      let presignResp = await resp.json();
      resp = await fetch(presignResp.url, {
        method: "PUT",
        headers: {
          "Content-Type": file.type,
        body: file,
      console.log("resp", resp);
    } catch (err) {
      console.error(err);
    } finally {
      setLoading(false);
  return (
    <div className="App">
      <header className="App-header">
        <form onSubmit={onSubmit}>
          <input type="file" />
          <br />
          <button disabled={loading}>Upload!</button>
        </form>
      </header>
    </div>
export default App;
Console output
create-multipart resp {$metadata: {…}, Bucket: 'demo-bucket', Key: 'test/Screen Shot 2022-10-05 at 3.54.43 PM.png', UploadId: '3svduYfAsQBXCtczhd58JgEhu5XTsJBqHY6J617e2DyKoTwYk2…d18Tpit5pCHGmMVj5KdSzc8wVU4cb6puUUJK1uHDeuUFw7BAD'}
resp Response {type: 'cors', url: 'https://demo-bucket.gateway.storjshare.io/test/Scr…5KdSzc8wVU4cb6puUUJK1uHDeuUFw7BAD&x-id=UploadPart', redirected: false, status: 200, ok: true, …}
etag "b855383d825388a64c782b30c330a822"
I can confirm that I’ve done exactly this flow with Storj using JS + Elixir, so it does work.
import * as React from "react";
import * as Sentry from "@sentry/browser";
import axios from "axios";
import { filesize } from "filesize";
import axiosRetry from "axios-retry";
import log from "loglevel";
import BusyIndicator from "./BusyIndicator";
import PQueue from "p-queue";
import {
  stubTrue,
  constant,
  cond,
  isEmpty,
  sumBy,
  reduce,
  map,
  values,
  orderBy,
  flow,
  keyBy,
  each,
  reject,
} from "lodash/fp";
import produce from "immer";
const UPLOAD_CONCURRENCY = 3;
const uploadAxios = axios.create();
axiosRetry(uploadAxios, { retries: 3, retryDelay: axiosRetry.exponentialDelay });
const uploadProgressAxios = axios.create();
axiosRetry(uploadProgressAxios, { retries: 10, retryDelay: axiosRetry.exponentialDelay });
 * The queue ensures we limit the number of uploads to Storj that are
 * occuring at the same time. Too many and we simply overload the users
 * connection.
 * We reject any parts that are marked as completed_at, no need to upload
 * them again. They will however still be marked as completed in the UI.
const queue = new PQueue({ concurrency: UPLOAD_CONCURRENCY, autoStart: true });
const logUploadPart = (uploadPart, level, message) => {
  log[level](`Part number [${uploadPart.partNumber}]: ${message}`);
export default function UploadPerform({ userDetails, uploadDetails, onError, onComplete }) {
  const partProgress = React.useRef(null);
  const [lastProgressAt, setLastProgressAt] = React.useState(null);
   * Called to create the upload job on the part before placing it in the
   * queue.
  const createUploadJob = React.useCallback((uploadPart, data) => {
    return async () => {
       * Perform the upload to Storj. We embed this code in an anonymous
       * function so it can be executed by the queue system.
      // record the start time of the upload
      const nextPartProgress = produce(partProgress.current, (draftPartProgress) => {
        draftPartProgress[uploadPart.id] = {
          ...draftPartProgress[uploadPart.id],
          startedAt: Date.now(),
      partProgress.current = nextPartProgress;
      try {
        logUploadPart(uploadPart, "info", "Starting upload");
        const uploadResponse = await uploadAxios({
          method: "put",
          url: uploadPart.uploadUrl,
          data,
          headers: {
            "Content-Type": uploadDetails.mimeType,
          onUploadProgress: async (progressEvent) => {
             * Calculate the progress of the upload to Storj and store it in
             * the partProgress ref. We also store the last progress event as
             * setting this will trigger a rerender of the React component.
             * Finally, we report the progress of this piece to the server so
             * that the dashboard can display the upload progress. If this
             * reporting fails, it is not fatal to the app.
            // Guard on not being able to calculate progress yet
            if (!progressEvent.loaded || !progressEvent.total) {
              return;
            const progress = progressEvent.loaded / progressEvent.total;
            // If we cannot calculate progress as part of this upload, bail out
            if (!progress) {
              return;
            const elapsedSeconds = (Date.now() - partProgress.current[uploadPart.id].startedAt) / 1000;
            const bytesCompleted = data.size * progress;
            const bytesPerSecond = bytesCompleted / elapsedSeconds;
                progress,
                bytesPerSecond,
            setLastProgressAt(Date.now());
            try {
              logUploadPart(uploadPart, "info", `Reporting progress to the server: ${progress}`);
              await uploadProgressAxios({
                data: {
                  progress,
                method: "put",
                url: `/api/upload_parts/${uploadPart.id}/progress`,
            } catch (e) {
              logUploadPart(uploadPart, "error", `Failed to report progress to server, this is not fatal`);
              Sentry.captureException(e);
         * Once the upload to Storj has completed, we then inform the FileYeet
         * backend that this piece has been completed. We pass the etag that was
         * given to us by Storj as this is needed to join the multipart upload
         * later.
        const etag = JSON.parse(uploadResponse.headers.etag);
        try {
          logUploadPart(uploadPart, "info", "Notifying server that part upload was completed");
          const { data } = await uploadProgressAxios({
            data: {
              etag,
            method: "put",
            url: `/api/upload_parts/${uploadPart.id}`,
              completedAt: data.completedAt,
              progress: data.progress,
        } catch (e) {
          logUploadPart(uploadPart, "error", "Failed to report to server that upload part completed");
          onError(e, "We had a problem performing the upload, please try again");
      } catch (e) {
        logUploadPart(uploadPart, "error", "Failed to upload part to S3");
   * Start jobs for each part to upload to the backend
  React.useEffect(() => {
    if (userDetails === null || uploadDetails === null) {
      return;
    (async () => {
       * Initialize a map of progress based on id, this is updated when we
       * start uploading to Storj. We use a ref here because of stale scope
       * when running the jobs in the queue.
      const initProgress = flow(
        orderBy(["partNumber"], ["asc"]),
        map((uploadPart) => {
          return {
            ...uploadPart,
            progress: 0.0,
            startedAt: null,
            bytesPerSecond: null,
        keyBy("id")
      )(uploadDetails.uploadParts);
      partProgress.current = initProgress;
      flow(
        reject("completedAt"),
        each((uploadPart) => {
          const file = userDetails.file.slice(uploadPart.partStart, uploadPart.partStart + uploadPart.partSize);
          const job = createUploadJob(uploadPart, file);
          queue.add(job);
      await queue.onIdle();
      onComplete(null);
  }, [userDetails, uploadDetails]);
  if (lastProgressAt === null) {
    return <BusyIndicator message="Getting ready to upload..." />;
  const uploadParts = values(partProgress.current);
  const renderedProgress = flow(
      const partProgressPercentage = uploadPart.progress * 100;
      return (
        <div key={uploadPart.id}>
          <div className="w-full flex items-center">
            <div className="w-full h-6 bg-slate-900 relative border-slate-700 border">
              <div className="h-6 bg-slate-600" style={{ width: `${partProgressPercentage}%` }} />
            </div>
          </div>
        </div>
  )(uploadParts);
  const amountUploaded = reduce((uploaded, uploadPart) => {
    return uploaded + uploadPart.partSize * uploadPart.progress;
  }, 0)(uploadParts);
  const totalProgress = amountUploaded / userDetails.file.size;
  // Sum the speed of all non-complete parts (i.e. those that are being uploaded currently)
  const sumBytesPerSecond = flow(
    reject(({ bytesPerSecond, completedAt }) => {
      return bytesPerSecond === null || completedAt !== null;
    cond([
      [isEmpty, constant(null)],
      [stubTrue, sumBy("bytesPerSecond")],
  )(uploadParts);
  const gridCols = (() => {
    switch (uploadParts.length) {
      case 1:
        return "grid-cols-1";
      case 2:
        return "grid-cols-2";
      case 3:
        return "grid-cols-3";
      case 4:
        return "grid-cols-4";
      default:
        return "grid-cols-5";
  return (
    <div className="text-center border border-white/20 p-8">
      <div className="text-center mb-4">
        <span className="text-white/80 block mb-2 text-3xl">{userDetails.uploaderFilename}</span>
      </div>
      <span className="text-white/90 text-2xl block mb-4">
        <span className="block mb-2 text-2xl">{Math.floor(totalProgress * 100)}% done</span>
        <span className="block mb-2 text-base">
          {sumBytesPerSecond === null ? "Calculating speed..." : `${filesize(sumBytesPerSecond)}/s`}
        </span>
      </span>
      <div className="mb-4">
        <div className={`grid border border-white/20 ${gridCols}`}>{renderedProgress}</div>
      </div>
    </div>
It’s a big chunk of code, but you can see I’m being given an etag back in the header.
If you want to see what the flow looks like from the browser, you can create an account here and perform an upload:
Open the network connections developer tools and you’ll be able to see the exchange of payloads between my server <> browser <> storj
I am such a foool - Sorry!
Turns out I just didn’t query “etag” correctly from the header. I was trying to get it directly via .etag :confused:
Thanks a lot for your help y’all!
Nice!
I have a feeling a had a couple of other gotchas along the way with this flow so I’m happy to help if you have any other questions.
