S3 or cli? What do you advice?
What do you advice, s3 or cli?
I’m currently developing a cloud system based on StorJ.
Thanks for your interest.
Jimmy
I think the consensus is that is you are able to directly integrate with the CLI then that’s the way to go.
Using the S3 gateway is great for compatibility and doesn’t require redesign of existing projects but if you’re making a new product may as well integrate with CLI directly. I gather its more efficient.
@will.topping is correct. A direct uplink integration will be a more efficient approach to architecture.
Let us know if you have any questions throughout the integration process!
Cheers,
Kevin
