I’m currently configuring an local Docker registry using registry:2 in Docker Compose, but when I attempting to push an image to the local registry, I’m seeing the following errors on the logs:
registry_1 | time="2022-01-14T05:09:23.354810007Z" level=error msg="response completed with error" err.code=unknown err.detail="s3aws: NoCredentialProviders: no valid providers in chain. Deprecated.
registry_1 | For verbose messaging see aws.Config.CredentialsChainVerboseErrors" err.message="unknown error" go.version=go1.11.2 http.request.host="localhost:5000" http.request.id=e8a97e1e-f350-44ee-9e76-e9c9b7efa0e1 http.request.method=HEAD http.request.remoteaddr="172.18.0.1:40400" http.request.uri="/v2/docker-library/registry/blobs/sha256:e2ead8259a04d39492c25c9548078200c5ec429f628dcf7b7535137954cc2df0" http.request.useragent="docker/20.10.12 go/go1.16.12 git-commit/459d0df kernel/5.13.0-1010-gcp os/linux arch/amd64 UpstreamClient(Docker-Client/20.10.12 \(linux\))" http.response.contenttype="application/json; charset=utf-8" http.response.duration=30.004240705s http.response.status=500 http.response.written=104 vars.digest="sha256:e2ead8259a04d39492c25c9548078200c5ec429f628dcf7b7535137954cc2df0" vars.name="docker-library/registry"
I configured the S3 backend configuration correctly, but did I miss something?
The full log and my compose file can be found at Log dump for running an local registry using Storj DCS S3 gateway as storage backend + config ($2235244) · Snippets · Snippets · GitLab, just in case you need to debug it by yourself.
