I have the docker services storj_postgres and storj_satellite in my compose file. For the satellite, the STORJ_DATABASE env is set to ‘postgres://postgres:passwordhere@storj_postgres/satellite?sslmode=disable’. Usually that connects to the storj_postgres service container, but for some reason the satellite seems to connect to localhost:
storj_satellite_1 | 2020-02-12T22:39:15.444Z INFO Configuration loaded from: /root/.local/share/storj/satellite/config.yaml
storj_satellite_1 | 2020-02-12T22:39:15.457Z DEBUG db Connected to: {"db source": "postgres://postgres:2aiFrcrwPweAoxrL947iqoYrTbqDV3yLU6br4dSmpz7@storj_postgres/satellite?sslmode=disable&application_name=Satellite"}
storj_satellite_1 | 2020-02-12T22:39:15.459Z DEBUG Unrecoverable error {"error": "Error creating revocation database: dial tcp 127.0.0.1:5432: connect: connection refused", "errorVerbose": "Error creating revocation database: dial tcp 127.0.0.1:5432: connect: connection refused\n\tmain.cmdRun:214\n\tstorj.io/storj/pkg/process.cleanup.func1.2:307\n\tstorj.io/storj/pkg/process.cleanup.func1:325\n\tgithub.com/spf13/cobra.(*Command).execute:826\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:914\n\tgithub.com/spf13/cobra.(*Command).Execute:864\n\tstorj.io/storj/pkg/process.ExecWithCustomConfig:84\n\tstorj.io/storj/pkg/process.ExecCustomDebug:66\n\tmain.main:455\n\truntime.main:203"}
storj_satellite_1 | Error: Error creating revocation database: dial tcp 127.0.0.1:5432: connect: connection refused
Why does this happen? Is this a bug?
