Script for Audits stat by satellites
Thank you. I was a little bit scared because the reset… :wink: Now i have checked with the other method and have seen that my audits are over 100 for all satellites. :+1:
Now the test-traffic should increase?
Well, your share of the traffic has increased. But keep in mind traffic is not constant to begin with. The amount you’ll see will still fluctuate.
and as the new version has changed the format of the JSON (but there is no documentation) I rewrote the satellite audit for powershell:
((curl http://127.0.0.1:14002/api/sno/).Content | ConvertFrom-Json).satellites.id | %{"$_"; ((curl http://127.0.0.1:14002/api/sno/satellite/$_).Content | ConvertFrom-Json).audit}
It’s already updated in the topic :slight_smile:
In my case I had to add -UseBasicParsing flag to the curl request of the PowerShell script for it to work.
((curl http://127.0.0.1:14002/api/sno -UseBasicParsing).Content | ConvertFrom-Json).satellites.id | %{"$_"; ((curl http://127.0.0.1:14002/api/sno/satellite/$_ -UseBasicParsing).Content | ConvertFrom-Json).audit}
After changing the node api, the script does not show the value :frowning:
@Alexey
Thank you for heads-up! I updated the first post.
On windows GUI
I tried the powershell command but it just returns with every single satilite only having 1 audit pr satilite - why? what did i do wrong?
There is no more audits count in the storagenode API. The 1 is a ratio, it’s 100% on the dashboard. There’s almost no point to use this script anymore - all this info is available on the dashboard.
If you want to know the vetting status, you can use this script instead: Earnings calculator (Update 2021-04-15: v10.1.2 - Detailed payout information: Now includes comparison to actual payout, postponed payouts due to threshold and transaction links!)
