Script to make write-hashtbl easier to use
Bash script to help with using write-hashtbl. Use “-h” for help.
Simply, you provide it the path to your hashstore, and it will walk you through each store on each satellite, optionally rebuilding one or all of them, removing 0 byte files - no batch mode.
#!/bin/bash
SATELLITES=("121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6" "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S" "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs" "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE")
STORES=("s0" "s1")
DEFAULT_DIR="/TestStorj/config/storage/hashstore"
# Store Command line argument
STORAGE_DIR=${1:-$DEFAULT_DIR}
WRITE_FLAGS="${@:2}"
function ShowHelpExit() {
    echo -e "\nrebuildHash.sh <HASHSTORE_PATH> <WRITE_HASHTBL>"
    echo -e "\n  <HASHSTORE_PATH>  Path to Hashtables.  eg: /mnt/hdd/config/storage/hashtable"
    echo -e "  <WRITE_HASHTBL>   Flags to parse to 'write_hashtbl' command"
    echo -e "\033[24G Flags:"
    echo -e "\033[28G -f, --fast            Skip some checks for faster processing"
    echo -e "\033[28G -s, --slots uint64    logSlots to use instead of counting"
    echo -e "\033[28G -k, --kind string     Kind of table to write\n"
    exit 1
function PromptYesNo() {
    read -p "Do you want to proceed? (y/n/CtrlC): " response
    case "$response" in
        [yY]|[yY][eE][sS])
            echo "Proceeding..."
            return 0
        [nN]|[nN][oO])
            echo "No.  Exiting..."
            return 1
            echo "No.  Exiting"
            return 1
    esac
    return 1
function FindInPath() {
    IFS=':' read -ra PATH_DIRS <<< "$PATH"
    local FOUND=0
    local FILENAME="${1}"
    for DIR in "${PATH_DIRS[@]}"
    do
        FILE_PATH="$DIR/$FILENAME"
        if [ -f "$FILE_PATH" ]; then
            echo "File '$FILENAME' found at: $FILE_PATH"
            return 0
        fi
    done
    return 1
function RecreateHashtable() {
   if [ "$1" == "" ]; then
     echo "Failed.  No Directory"
     return 2
   fi
   local location="${1}"
   echo "ReCreate Hashtable: ${location}"
   cd "${location}"
   if [ -f "${location}/meta/lock" ]; then
       echo "lock File exists.  Ensure StorageNode is NOT running."
       echo "Corruption may occur if hashtables are recreated whilst Node is running"
       echo "Ensure StorageNode is stopped before proceeding"
       echo ""
       return 2
   fi
   # 0 Byte Hashtable is useless, just remove them
   find ./meta -type f -size 0c -delete
   # Find 0B Files, Give option to delete them.
   local noFiles=$(eval "find . -type f -size 0c | wc -l")
   if [[ "$noFiles" -gt 0 ]]; then
       echo "Found ${noFiles} NULL Files -  Remove?"
       if PromptYesNo; then
           echo "Deleting NULL Files"
           find . -type f -size 0c -delete
       else
           echo "Not Deleting NULL Files"
       fi
   fi
   # Option to Backup existing hashtable
   echo "Checkup for Backup"
   if [ -d "${location}/meta.bak" ]; then
       echo "Remove Previous hashtable Backup"
           echo "Removing Previous Backup"
           rm -f meta.bak/*
           echo "Backup Existing meta Data"
           mv meta/* meta.bak/
       else
           # Backup contents Contents of "meta" directory
           echo "Removing Content of 'meta' directory"
           mv -f meta/hashtbl* meta.bak/
       fi
   else
       # No Previous Backup, Create Backup Automatically
       mkdir meta.bak
       mv -f meta/* meta.bak/
   fi
   cd meta
   echo "Running: write-hashtbl ${WRITE_FLAGS} ${location}"
   return $?
# Check for Help Option
if [[ "$1" == "-h" ]]; then
    ShowHelpExit
fi
# Check we can find write-hashtbl binary.
export PATH=$PATH:~/go/bin
FindInPath write-hashtbl
RESULT=$?
if [[ "$RESULT" -eq 1 ]]; then
    echo "Binary NOT Found.  Please ensure 'write-hashtbl' is in PATH and executable"
    exit 1
fi
# Check Storage Directory Exists
if [ ! -d $STORAGE_DIR ]; then
   echo "Directory Does not Exist\n"
   showHelpExit
fi
# Iterate through all Satellites and Stores
storeCount=0
for item in "${SATELLITES[@]}"
do
   for store in "${STORES[@]}"
   do
       ((storeCount++))
       currentDir="${STORAGE_DIR}/${item}/${store}"
       echo ""
       if [ -d $currentDir ]; then
           echo "Rebuild Hashstore: ${item}/${store} - #${storeCount}"
              RecreateHashtable ${currentDir}
              RESULT=$?
              if [[ "${RESULT}" -eq 2 ]]; then
                  if ! PromptYesNo; then
                      exit 1
                  fi
              fi
           else
              echo "Skipping ${item}/${store}"
           fi
       else
           echo -e "WARNING: Logfile Directory ${currentDir} Does NOT Exist\n"
       fi
   done
done
exit 0
