New second node not starting. In docker ps -a have cycling restart.
Log:
Error: Error starting master database on storagenode: database: database info does not exist stat config/storage/info.db: no such file or directory
storj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:344
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:313
storj.io/storj/storagenode/storagenodedb.Open:245
main.cmdRun:151
storj.io/private/process.cleanup.func1.4:353
storj.io/private/process.cleanup.func1:371
github.com/spf13/cobra.(*Command).execute:840
github.com/spf13/cobra.(*Command).ExecuteC:945
github.com/spf13/cobra.(*Command).Execute:885
storj.io/private/process.ExecWithCustomConfig:88
storj.io/private/process.ExecCustomDebug:70
main.main:330
runtime.main:203
But path is present in file system. Database files - not.
Should the new node create new files if they does not exist, or not?
My start options:
–mount type=bind,source="/home/user/.local/share/storj/identity/storagenode1",destination=/app/identity
–mount type=bind,source="/storj1",destination=/app/config
–mount type=bind,source="/db-storj1",target=/app/db
–name storagenode1 storjlabs/storagenode:latest
In the config.yaml :
storage2.database-dir: “/app/db”
Whats a problem?
So… I touched empty db files:
info.db
orders.db
piece_expiration.db
pieceinfo.db
piece_spaced_used.db
reputation.db
storage_usage.db
used_serial.db
satellites.db
notifications.db
heldamount.db
pricing.db
And node starting. But not shows satellites in web dashboard.
Maybe i need to replace satellites.db from the first node?
Nope… satellites now is showing.
It’s bug in new version?
Could you describe what you exactly did?
because I have tried, I specified an empty folder for the storage and all went well - it’s created an config.yaml
file and storage
folder and all databases there.
I created new node. But first start was been with wrong options like this:
Then i added right option:
–mount type=bind,source="/home/sewir/.local/share/storj/identity/storagenode1",destination=/app/identity
And node created container and config.yaml, and storage folder with temp, blob, etc. But without all db-files. Until i created empty db-files manually, node was have errors in the log.
Yes, if the destination folder is not empty, the DB files will not be created. If the DB files are exist, but config.yaml
is not, it will fail to start because of DBs are exist.
The only different mountpoint for databases is not enough, you should also specify the storage2.database-dir:
option in the config file or --storage2.database-dir
option in the storagenode setup
command.
Since it’s a docker version, it doesn’t transfer any setup option to the config file:
