Hello all,
I have two installations of Storj. They both are on separate PCs. The one works fine and did from the moment I finished installing it. The other installation says offline. I’m sure I’m missing something simple. I have a No-IP DDNS and have ported my router.
Any suggestions? Using a port checker it says the port for my second application is closed. I’ve tried everything I can think of to open it. Is it possible that the storagenode isn’t actually running which causes the port tool to think the port is closed?
Thanks in advance
