Hi,
for the second node on same host we should use this: "p 28968:28967/tcp -p 28968:28967/udp "
But what happens if we are using this: "p 28968:28968/tcp -p 28968:28968/udp "
Does the node running fine with 28968:28968 ?
Hi,
No.
You can do it, but you need to either modify your config.yaml
or use option --server.address
to listen a different port. But - why?
Just use a port mapping option in your docker run
command and change only port number for your host, like -p 28968:28967/tcp -p 28968:28967/udp
