Monitoring the connections to the storj instance I have found some IP address that are present in the some abuse IP website database that trying to connect to the open Port of storj.
Now I can’t see if this IP’s are store j nodes… But what about software security of storj?
For other my web applications I limit connections using Geo IP with a firewall and ips.
What security measures are used in the docker storj software?
Thank you.
