I think I didnโt get this works (cgroup_enable=memory cgroup_memory=1 swapaccount=1).
I created the node Identity on a windows PC. Mainly because the identity that I created on rpi only has the difficulty of 30 which doesnโt meet the requirement of 36.
Thank you. I was planning to install Ubuntu on Raspberry but just noticed the instructions are for Raspbian Stretch lite. Are there any instructions out there for Ubuntu?
The official documentation @zeyacry linked above (https://documentation.storj.io/) should work for setting up your storage node on Ubuntu. Most of the steps will be the same across different operating systems.
