Setup 2nd node but always get same Auth-key
Hello,
I want to setup a 2nd Node. But when i request a auth-key i always get the same as i got for my first node.
Is this right? can i sign my 2nd node with the same auth-key?
(I build a new identity for it).
PS: Ah, i see, i have to use another email-adress.
No You cant use the same authkey and you can use the same email address as well you get a new authkey everytime you sign up as long as you used the old one.
yes, thx for this. i messed up with my emails and the actual key i never used befor. ok. so i can go on.
i succesfull startet my 2nd node, just for information :wink:
