it is drive me back to Barna@HAL9000-NAS:/volume1/home/Barna $
Okay, now just the command:
cd /volume1/home/Barna/_STROJ && ls
There is a “bind” option in Portainer, but it doesn’t relieve the user from thinking while configuring ![]()
My guess is that the one-time (!!!) command that configures your node is:
sudo docker run --rm -e SETUP="true" \
--user $(id -u):$(id -g) \
--mount type=bind,source="/volume1/home/Barna/_STROJ/Identity/storagenode",destination=/app/identity \
--mount type=bind,source="/volume1/home/Barna/_STROJ/storage",destination=/app/config \
sudo docker run --rm -e SETUP="true" --user $(id -u):$(id -g) --mount type=bind,source="/volume1/home/Barna/_STORJ/Identity/storagenode",destination=/app/identity --mount type=bind,source="/volume1/home/Barna/_STORJ/storage",destination=/app/config --name storagenode storjlabs/storagenode:latest
Unfortunately it’s converted to -v /srv/dev-disk-by-uuid-...:/app/identity -v /srv/dev-disk-by-uuid-...:/app/config, not --mount.
It’s less dangerous now, because we have checks for special file which is created only on setup, but it’s better to worry than sorry.
Because if disk disappear, docker with option -v will create empty volumes and mount them instead of disk.
Oh, they learned how to use --mount? Respect
- Thank you very much peem!
- It is working!
I am also happy
May the stay of SNO be for you what you have done best in your life ![]()
For all Asustor users, Deadbolt Ransomware! :
I’m also trying to install Storj on the same NAS.
My container not start.
Can anyone help?
Thanks
The conteiner log is:
2022-03-01T17:30:06.141Z ERROR Failed to load identity. {“error”: “file or directory not found: open identity/identity.cert: no such file or directory”, “errorVerbose”: “file or directory not found: open identity/identity.cert: no such file or directory\n\tstorj.io/common/identity.Config.Load:329\n\tmain.cmdRun:182\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.ExecCustomDebug:70\n\tmain.main:474\n\truntime.main:255”}
Error: Failed to load identity: file or directory not found: open identity/identity.cert: no such file or directory
main.cmdRun:182
main.main:474
runtime.main:255
main.cmdRun:182
main.main:474
runtime.main:255
Seems you did not mount the identity folder from your NAS filesystem to the /app/identity folder inside the container.
Perhaps you did not mount your data location too.
Please, stop and remove the container and run it again with all required parameters:
I tried to configure by SSH and the conteineir already works.
I Used
docker run --rm -e SETUP=“true”
–user $(id -u):$(id -g)
–mount type=bind,source="/volume1/home/LHM/Storj/Identity/storagenode",destination=/app/identity
–mount type=bind,source="/volume1/home/LHM/Storj/Storage",destination=/app/config
-p 28967:28967/tcp
-p 28967:28967/udp
-p 127.0.0.1:14002:14002
-e WALLET=“0x4d95bcc771F4A5a2CcDdc16d7dfCE06A62416655”
-e EMAIL=“luis.xxxx@xxxx.pt”
-e ADDRESS=“xxxxxx.ddns.me:28967”
-e STORAGE=“2TB”
The problem now seems to me to be the doors closed.
2022-03-02T17:25:36.785Z INFO Configuration loaded {“Location”: “/app/config/config.yaml”}
2022-03-02T17:25:36.790Z INFO Operator email {“Address”: “luis.xxxx@xxxx.pt”}
2022-03-02T17:25:36.790Z INFO Operator wallet {“Address”: “0x4d95bcc771F4A5a2CcDdc16d7dfCE06A62416655”}
2022-03-02T17:25:37.729Z INFO Telemetry enabled {“instance ID”: “1SGXst5g2uzR6hMoz3qQYHgMmssgr7tNDDSFvy8BGQ1NfLU2CP”}
2022-03-02T17:25:37.805Z INFO db.migration Database Version {“version”: 53}
2022-03-02T17:25:39.085Z INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2022-03-02T17:25:40.049Z INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2022-03-02T17:25:40.050Z INFO Node 1SGXst5g2uzR6hMoz3qQYHgMmssgr7tNDDSFvy8BGQ1NfLU2CP started
2022-03-02T17:25:40.050Z INFO Public server started on [::]:28967
2022-03-02T17:25:40.050Z INFO Private server started on 127.0.0.1:7778
2022-03-02T17:25:40.050Z INFO failed to sufficiently increase receive buffer size (was: 224 kiB, wanted: 2048 kiB, got: 448 kiB). See UDP Receive Buffer Size · lucas-clemente/quic-go Wiki · GitHub for details.
2022-03-02T17:25:45.549Z WARN contact:service failed PingMe request to satellite {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “error”: “ping satellite: check-in network: failed to ping node (ID: 1SGXst5g2uzR6hMoz3qQYHgMmssgr7tNDDSFvy8BGQ1NfLU2CP) at address: xxxxxxxx.ddns.me:28967, err: contact: failed to dial storage node (ID: 1SGXst5g2uzR6hMoz3qQYHgMmssgr7tNDDSFvy8BGQ1NfLU2CP) at address xxxxxxx.ddns.me:28967 using QUIC: rpc: quic: timeout: no recent network activity”, “errorVerbose”: “ping satellite: check-in network: failed to ping node (ID: 1SGXst5g2uzR6hMoz3qQYHgMmssgr7tNDDSFvy8BGQ1NfLU2CP) at address: xxxxxxx.ddns.me:28967, err: contact: failed to dial storage node (ID: 1SGXst5g2uzR6hMoz3qQYHgMmssgr7tNDDSFvy8BGQ1NfLU2CP) at address xxxxxxx.ddns.me:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:841\n\tstorj.io/storj/storagenode.(*Peer).Run:880\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.ExecCustomDebug:70\n\tmain.main:474\n\truntime.main:255”}
I have on the local network more nodes on windows, about 50TB in data
Every computer on my local network has a different port.
I do not understand also because config.yaml does not have the correct configuration.
the public address of the node, useful for nodes behind NAT
contact.external-address: “”
path to the certificate chain for this identity
identity.cert-path: identity/identity.cert
path to the private key for this identity
identity.key-path: identity/identity.key
operator email address
operator.email: “”
operator wallet address
operator.wallet: “”
public address to listen on
server.address: :""
However in the NAS is being more complicated. ![]()
This command should be used only once.
This is normal for docker setup, all required parameters you provide in the CLI, they have a precedence above parameters in config.yaml.
The ping failed means that your address is not available from outside.
Please, use this checklist to troubleshoot:
I would only add, that you need to forward UDP 28967 as well or modify your port forwarding rule to forward both protocols - TCP+UDP.
Please, also make sure to add allowance rules to the firewall on your NAS.
Finally online.
The problem was the ports closed.
I routed port 28967 in to rooter,.
Forwarding in NAS and rooter i couldn’t open the port.
Thanks
