Hi guys!
I have tried to sign up to create a new node and after clicking all the requirements on the website, clicking “Continue” does nothing.
I have tried Safari, Firefox (on MacOS and iOS), IE and Edge on (Windows 10) with all protections off in multiple computers and nothing seems to work.
Can anyone suggest a way around this?
Many thanks
Try once more with Chrome.
Is that the only way out? I don’t like to use Google stuff and would be loathe to install it just for this…
It looks like, we’re all complaining about it for a long time. There is a portable version available, which doesn’t need to be installed. Just delete the folder afterwards.
Thanks for that, I appreciate it.
I use Brave browser and it works., I just tried it.
You can also update to the Chromium based version of Edge, that works too and it’s actually the first time in a long time MS has had a great browser.
