Continuing the discussion from Did anybody tried oracle free tier as vpn?:
This modified approach avoids messing with iptables rules and accomplishes the same outcome in a drastically simpler and straightforward way, taking advantage of firewalld, that is already running on the oracle linux instances anyway.
Setup goes as follows:
Configure firewall on the oracle gateway in the web or cli console, to allow your node’s port and wireguard port, as described in the linked post above
Configure Wireguard tunnel, following whatever tutorial you like. Just bare minimum, no preUp/psotDown rules or anything else fancy.
Example:
on the server:# cat /etc/wireguard/wg0.conf [Interface] PrivateKey = xxx ListenPort = 51820 Address = 10.143.221.13/32 [Peer] PublicKey = yyy AllowedIPs = 10.143.221.14/32
on the client:
# cat /usr/local/etc/wireguard/oracle.conf [Interface] PrivateKey = zzz Address = 10.143.221.14/32 [Peer] PublicKey = nnn AllowedIPs = 0.0.0.0/0 Endpoint = oracle_instance_public_ip:51820 PersistentKeepalive = 25
That’s it, nothing else. Note, here we are setting
AllowedIPs
to0.0.0.0/0
– this is to send all traffic originating on the node via VPN, specifically, the inadyn traffic, that would update DDNS if you used one. If you don’t want that – set only server’s address in the allowed IPs instead. In this case there is no need to enable masquerading on the instance below either. -
Now the packet forwarding bits, without the hard to follow and maintain iptables. Run this script, making adjustments to ports, addresses, or interface names if needed:
WG_CLIENT_IP=10.143.221.14 WG_CLIENT_PORT_EXT=28967 WG_CLEINT_PORT_INT=28967 WG_IFACE="wg0" # Oracle default external zone is called "public", not "external" EXT_ZONE="public" # Allow wireguard connections firewall-cmd --zone="$EXT_ZONE" --add-port=51820/udp # Allow node connections: firewall-cmd --zone="$EXT_ZONE" --add-port=$WG_CLIENT_PORT_EXT/udp firewall-cmd --zone="$EXT_ZONE" --add-port=$WG_CLIENT_PORT_EXT/tcp # Enable masquerading on the "$EXT_ZONE" zone oracle has configured. Predefined "external" # zone would have had that enabled. This is not needed if you don't want to route all traffic # that originates on the node through the wireguard, see above. firewall-cmd --zone="$EXT_ZONE" --add-masquerade # Add forwarding rules for your nodes' port firewall-cmd --zone="$EXT_ZONE" --add-forward-port="port=$WG_CLIENT_PORT_EXT:proto=tcp:toport=$WG_CLEINT_PORT_INT:toaddr=$WG_CLIENT_IP" firewall-cmd --zone="$EXT_ZONE" --add-forward-port="port=$WG_CLIENT_PORT_EXT:proto=udp:toport=$WG_CLEINT_PORT_INT:toaddr=$WG_CLIENT_IP" # add wireguard interface to internal zone firewall-cmd --zone=internal --add-interface="$WG_IFACE" # Review: firewall-cmd --get-active-zones firewall-cmd --info-zone="$EXT_ZONE"
you shall see something like this:
# firewall-cmd --get-active-zones internal interfaces: wg0 public interfaces: enp0s3 # firewall-cmd --info-zone=public public (active) target: default icmp-block-inversion: no interfaces: enp0s3 sources: services: dhcpv6-client ssh ports: 51820/udp 28967/udp 28967/tcp protocols: forward: no masquerade: yes forward-ports: port=28967:proto=tcp:toport=28967:toaddr=10.143.221.14 port=28967:proto=udp:toport=28967:toaddr=10.143.221.14 source-ports: icmp-blocks: rich rules:
Connect wireguard, startup your node, make sure all works. Then make the firewalld configuration persistent:
firewall-cmd --runtime-to-permanent
Bonus:
Configure alarm on the query BytesToIgw[1d].sum() > 333,000,000,000
on oct_internet_gateway
– this way you will get notified if you used up over 10TB/30 of traffic in one day, indicating that you might want to eventually switch to some other vpn service with unmetered egress, as you will likely blow through free allowance.
