Slice error in upload write function
I am using lib/uplinkc for uploading object on storj V3 . for uploading object i am using following uplinkc functions
  1. upload
  2. upload_write
  3. upload_commit
    my code is working fine on older version of uplinkc but when i have download/updated version of storj .i am getting following error while calling uplink_write function :
panic: runtime error: makeslice: len out of range [recovered]
goroutine 82 [running]:
gopkg.in/spacemonkeygo/monkit%2ev2.newSpan.func1(0xc00009c200)
	/Users/qq/go/pkg/mod/gopkg.in/spacemonkeygo/monkit.v2@v2.0.0-20190623001553-09813957f0a8/ctx17.go:151 +0x375
panic(0x10661cb20, 0x1067b0f20)
	/usr/local/go/src/runtime/panic.go:679 +0x1b2
gopkg.in/spacemonkeygo/monkit%2ev2.newSpan.func1(0xc00009c250)
gopkg.in/spacemonkeygo/monkit%2ev2.newSpan.func1(0xc000190020)
storj.io/uplink/storage/segments.(*PeekThresholdReader).IsLargerThan(0xc00018e330, 0xffffffffefbfea30, 0x20, 0x2, 0xc000034400)
	/Users/qq/go/pkg/mod/storj.io/uplink@v0.0.0-20200109100422-69086b6ee4a8/storage/segments/peek.go:47 +0x68
storj.io/uplink/storage/streams.(*streamStore).upload(0xc0000cc730, 0x1067ccee0, 0xc000240140, 0xc0000a2060, 0xf, 0xc0000a2070, 0x1b, 0xc0000a2090, 0x2b, 0x30, ...)
	/Users/qq/go/pkg/mod/storj.io/uplink@v0.0.0-20200109100422-69086b6ee4a8/storage/streams/store.go:176 +0x95a
storj.io/uplink/storage/streams.(*streamStore).Put(0xc0000cc730, 0x1067ccee0, 0xc0002400a0, 0xc0000a2060, 0xf, 0xc0000a2070, 0x1b, 0xc0000a2090, 0x2b, 0x30, ...)
	/Users/qq/go/pkg/mod/storj.io/uplink@v0.0.0-20200109100422-69086b6ee4a8/storage/streams/store.go:92 +0x2c3
storj.io/uplink/storage/streams.(*shimStore).Put(0xc000128070, 0x1067ccee0, 0xc00021ea00, 0xc0000a2060, 0x2b, 0xc0000a2002, 0x1067bb780, 0xc0000100d0, 0x106c30358, 0x0, ...)
	/Users/qq/go/pkg/mod/storj.io/uplink@v0.0.0-20200109100422-69086b6ee4a8/storage/streams/shim.go:49 +0x26e
storj.io/uplink/stream.NewUpload.func1(0xc004272f68, 0x0)
	/Users/qq/go/pkg/mod/storj.io/uplink@v0.0.0-20200109100422-69086b6ee4a8/stream/upload.go:53 +0x2aa
golang.org/x/sync/errgroup.(*Group).Go.func1(0xc000192048, 0xc00017a280)
	/Users/qq/go/pkg/mod/golang.org/x/sync@v0.0.0-20190911185100-cd5d95a43a6e/errgroup/errgroup.go:57 +0x64
created by golang.org/x/sync/errgroup.(*Group).Go
	/Users/qq/go/pkg/mod/golang.org/x/sync@v0.0.0-20190911185100-cd5d95a43a6e/errgroup/errgroup.go:54 +0x66
I have added print statement in the go code to check. these are output of print statement :
Data on the 0x104469540 Upload write
Upload : &{{0xc00017a100 0x106088450} 0xc000192000}
Length : 18
Buf : [72 101 108 108 111 83 116 111 114 106 32 69 120 97 109 112 108 101]
Upload function
func upload_write(uploader C.UploaderRef, bytes *C.uint8_t, length C.size_t, cErr **C.char) C.size_t {
	fmt.Println("Upload write ")
	upload, ok := universe.Get(uploader._handle).(*Upload)
	if !ok {
		*cErr = C.CString("invalid uploader")
		return C.size_t(0)
	fmt.Println("Upload : ",upload)
	ilength, ok := safeConvertToInt(length)
	if !ok || ilength < 0 {
		*cErr = C.CString("invalid length: too large or negative")
		return C.size_t(0)
	fmt.Println("Length : ",length)
	if err := upload.ctx.Err(); err != nil {
		if !errs2.IsCanceled(err) {
			*cErr = C.CString(fmt.Sprintf("%+v", err))
		return C.size_t(0)
	buf := *(*[]byte)(unsafe.Pointer(
		&reflect.SliceHeader{
			Data: uintptr(unsafe.Pointer(bytes)),
			Len:  ilength,
			Cap:  ilength,
	fmt.Println("Buf : ",buf)
	n, err := upload.wc.Write(buf)
	if err != nil {
	fmt.Println("Returning size : ",n)
	return C.size_t(n)
Hi @shivam201312,
Could you provide some more information about the version you were using that worked correctly vs. the version you are using currently that doesn’t work correctly?
Any additional information you can provide will make the debugging process easier.
@shivam201312 there was a change in how we get a Go slice from C in this commit https://review.dev.storj.io/c/storj/storj/+/246 and it got released with the version 0.28.2.
I guess that before you were using any previous version.
Please, can you checkout to any previous version and compile the libuplinkc and use it in your application to verify that you don’t get the error?
Many thanks in advance.
@moby and @ifraixedes Thank you for replying i will get back you.
