The values in the dashboard and satellite json appear inconsistent. Is there some documentation for it?
Example from my storagenode:
curl 127.0.0.1:14002/api/
“diskSpace”: {
“used”: 26.643240448,
“bandwidth”: {
“used”: 73.266891008,
I understand these units are GB (which I hope get corrected to bytes soon). The node is currently using 26GB disk, and 73GB bandwidth. ‘df’ confirms 26GB used. thats fine.
$ curl 127.0.0.1:14002/api/satellite/118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW
“storageSummary”: 569771936986.2192,
“bandwidthSummary”: 21154171392,
these are actual bytes so divided into GB its Storage total 530GB and Bandwith total 19GB.
Presumably the storage total is continuously increasing so I wouldnt expect it to match the current 26GB used, but if its cumulative, and presuming the bandwidth total covers the same time period, bandwidth total would need to at least equal the storage total since every byte stored comes over the ‘bandwidth’.
