How do I delete a bucket from the Storj GUI?
The bucket is not empty
I seem to have forgotten the encryption code
I do not need or want the data - its test data. I have been testing Storj - which works very well - its just the backup program I have been using is a bit janky and wiped its config out. (along with the encryption key and anything else I needed)
Its a free account - so I would happily delete the account - I can always set up another one. BUt I don’t seem to have a way of doing that either
Of course, you just need to download a binary, setup and use it.
If you do not want to install it to a common path like /usr/local/bin/, you can always use the binary from the location where you extracted it from the zip archive, i.e.
./uplink ls
to make it happen you need to set an executable bit for the binary first:
