I’ve got a strange issue going on with QUIC. I’ve had it all running fine, and recently I noticed it is now listed as misconfigured.
First I used the connect-test go program from Storj. I ran it from my laptop (so on same network as Storj node). I xxxxx out the end of the ID, not sure if that is something that is ok to share or not.
macbookair:storj user$ go run ./cmd/tools/connect-test 10.100.1.31:28967
QUIC success 1CiX9mvbUkhwv4aEkghE4tDUXBbzkxxxxxxxxxxxxxxxxxxxx
TCP success 1CiX9mvbUkhwv4aEkghE4tDUXBbzkxxxxxxxxxxxxxxxxxxxx
So this at least tells me my node is still running, and UDP 28967 is working.
Next, I connected my laptop to another network outside my network, and hit my public IP:
macbookair:storj kupan787$ go run ./cmd/tools/connect-test 76.15X.XX.XX:28967
QUIC fail quic: timeout: no recent network activity
Ok, so it looks like maybe a router issue with port forwarding.
I checked my router, and the same rule that is setup is for both TCP and UDP:
TCP is obviously working, as my node shows as Online and the connect-test passes for TCP in both cases. I’m at a loss why UDP is not passing through. I’ve checked other rules I have that pass UDP, and those rules are working fine. I’m not sure if there is anything else to check, or if it seems like I am at least heading down the right track.
also try to create 2 rules- one for tcp and another for udp port. also try different destination and translation ports (do not forget to change it in config file and restart your node)+ check version of running software
Is it possible to set QUIC/UDP to use a different port from TCP in storj? Or if I try changing the port, is there only one setting which controls both TCP and UDP?
2023-02-22T22:45:12.906Z WARN contact:service Your node is still considered to be online but encountered an error. {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Error": "contact: failed to ping storage node using QUIC, your node indicated error code: 0, rpc: quic: timeout: no recent network activity"}
2023-02-22T22:45:13.182Z WARN contact:service Your node is still considered to be online but encountered an error. {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Error": "contact: failed to ping storage node using QUIC, your node indicated error code: 0, rpc: quic: timeout: no recent network activity"}
2023-02-22T22:45:13.257Z WARN contact:service Your node is still considered to be online but encountered an error. {"Process": "storagenode", "Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "Error": "contact: failed to ping storage node using QUIC, your node indicated error code: 0, rpc: quic: timeout: no recent network activity"}
2023-02-22T22:45:13.753Z WARN contact:service Your node is still considered to be online but encountered an error. {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Error": "contact: failed to ping storage node using QUIC, your node indicated error code: 0, rpc: quic: timeout: no recent network activity"}
2023-02-22T22:45:13.886Z WARN contact:service Your node is still considered to be online but encountered an error. {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Error": "contact: failed to ping storage node using QUIC, your node indicated error code: 0, rpc: quic: timeout: no recent network activity"}
2023-02-22T22:45:13.887Z WARN contact:service Your node is still considered to be online but encountered an error. {"Process": "storagenode", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Error": "contact: failed to ping storage node using QUIC, your node indicated error code: 0, rpc: quic: timeout: no recent network activity"}
I’m assuming this isn’t saying anything new. I’m going to try changing ports, and see if that works.
I was doing some changes, and was setting up a new Xbox. I had moved those rules above my Storj Node rules, and I messed up the Xbox rules and forgot to translate one of the UDP ports…so it was taking everything!
I just moved the Storj rules to the top, and fixed the Xbox ones. All good now.
