Hi,
there is a way to speed up the Node Garceful Exit, the default value is 30 days but I have some issue with my disk and could be broken before 30days !
Alexey
July 11, 2024, 7:02am
2
Hi!
Not anymore. It’s required to be 30 days online, that’s it.
Warning: Read this carefully before you start
Please read the following information carefully and ask any questions your might have before executing graceful exit. Once graceful exit is started there is currently no way to stop or cancel it. Think about the consequences twice before you call it.
Requirements:
Storage node has joined the network more than 15 months ago (requirement temporarily reduced to 6 months).
Storage node is healthy and hasn’t lost any significant amount of data. Disqua…
What happens if my disk dies before 30 days?
brizio71:
before 30 days?
You will fail graceful exit and lose your held amount.
Wow… it seems not really fair… expecially for node operator that runs storj nodes since the beginning!!!
Roxor
July 11, 2024, 9:47am
6
It’s not fair that if you lose the data … you lose the coins held to repair the data if you lost it?
All Storj asks of you is that if they give you some data now… you can give it back later. You have one job!
Toyoo
July 11, 2024, 10:29pm
7
You can migrate data to a healthy drive and then trigger graceful exit.
