A few months back, I swapped out my firewall box, and then upgraded to fiber to the home internet. When I swapped the firewall, I forgot to add the port forwarding for the Storj Node. My node was suspended. I finally realized what was happening and opened the ports, only to have my node disqualified.
Before doing enough research, I went in an deleted everything and tried to reinstall it and start over. I have gotten as far as confirming the identity, but when I start the node, the dashboard is unreachable.
What all do I need to delete, so I can actually start over from scratch?
Did you try to use your old identity, or did you create a new one? I new identity will need to be created. You can use the same email address if you wish.
Are you unable to reach both the CLI and web dashboards? You should check the storagenode logs to see what the error messages say.
I am assumning this is another Ubuntu / docker node.
Recently a setup step has also been added. You can’t just run your node with the docker run command the first time anymore. Refer to documentation.storj.io for full details.
So delete the old config file and run setup again? Or do I have to delete the old config file, and the identity I just confirmed, and then restart with a new identity again?
