if I follow the static mount directions and add my STORJ hard drive to the etc/fstab file I end up in emergency mode if I restart the PC.
This is what my etc/fstab file looks like:
And this where I end up upon restarting:
From emergency mode I can edit the etc/fstab file and delete the line for the STORJ drive. Then I can reboot and get into ubuntu just fine. From there I can just put the STORJ drive line back into the fstab file and run “mount -a.” In other words, I currently have a work around to keep the node up and the PC running.
However, this work around is not ideal because while the PC is an “always on” PC there is still the potential for a brown out or something else causing the PC to restart. Ideally the node is up and running on start up.
I also cannot seem to figure out what’s causing my QUIC to be misconfigured. I don’t think the issues are related but I’m not an expert on node operating or computers by any means
Anyone have any ideas on what might be the problem?
Thanks in advance.
