I am running a storage node for 4 months now and suddenly my dashboard is showing that I am offline. I have a software that shows incoming and out coming data and I can see that my HDD is being actively used. Storage node and storage node updater services are running. Any one experiencing this issue?
2020-08-17T17:21:16.433+0300 ERROR piecestore failed to add order {“error”: “ordersdb error: disk I/O erro
r: The device is not ready.”, “errorVerbose”: "ordersdb error: disk I/O error: The device is not ready.\n\tstorj.io
I cannot paste it fully but it says : {“error”: "Error starting master database on storagenode: storage node database error: file is not a database
Followed the guide. orders.db has this error. The 13step on the guide (.read notrans file) I get an error:
Error: near line 1: near “?PRAGMA”: syntax error
CREATE TABLE unsent_order (
satellite_id BLOB NOT NULL,
serial_number BLOB NOT NULL,
order_limit_serialized BLOB NOT NULL, -- serialized pb.OrderLimit
order_serialized BLOB NOT NULL, -- serialized pb.Order
order_limit_expiration TIMESTAMP NOT NULL, -- when is the deadline for sending it
uplink_cert_id INTEGER NOT NULL,
FOREIGN KEY(uplink_cert_id) REFERENCES certificate(cert_id)
CREATE TABLE order_archive_ (
status INTEGER NOT NULL,
archived_at TIMESTAMP NOT NULL,
CREATE UNIQUE INDEX idx_orders ON unsent_order(satellite_id, serial_number);
CREATE TABLE versions (version int, commited_at text);
.exit
