My storage node has one big problem at the moment. Every full hour it is sending all orders to the satellite. This process takes a few minutes and is locking my sqlite3 database for a long time. In my logfile I get a lof of upload, download and audit requests. I am not responding to them for 5-20 minutes.
Lets take a look whats happening in the background. By default the storage node opens a random debug port and you can get a lot of information from it. You can use a specific port by adding debug.addr: ":7777"
to your config file.
curl localhost:7777/mon/ps | less
is showing what the storage node is doing at the moment. In my case it was showing many uploads and downloads blocked by a database query for 5 minutes:
[562667889748747363] storj.io/storj/storagenode/piecestore.(*Endpoint).Upload() (elapsed: 4m12.620860502s)
[1612100082723656965] storj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimit() (elapsed: 4m12.62057045s)
[784185589668157969] storj.io/storj/storagenode/storagenodedb.(*usedSerials).Add() (elapsed: 4m12.619908614s)
We looked into it and identified multiple issues:
1.) The database is locked and that is blocking everything.
2.) On each request we are checking used space with a database query that will sum up more than 1 million entries.
3.) On each request we are checking used bandwidth. Again a table with more than 1 million entries.
Now we try to fix these issues one by one. Stay tuned
