Storage Node Installation - Github Releases
Hi, I am running a storj node on docker. Actually on Version 0.34.6.
I just checked github.com/storj/storj/releases and found out, that newer versions exists.
Version 0.35.3 and even Version 1.0.0
I am not very familiar with github, but it looks to me that I am running my node not on latest release.
I have installed watchtower also. But no update.
So I removed all containers and did a reinstall of the docker containers. Nothing changed I am still on Version 0.34.6 when I am doing installition according documentation.storj.io/setup/cli/docker
Am I am running on the proper software version? or is the documentation of the docker setup outdated? pls support
best Wolfgang
Here is the answer to your question
thx for the info.
But how to read github? How can I find out, that I am running on proper version, just by checking github releases? How can I prove it?
Here is the answer to your second question :slight_smile:
