Thanks, But now possibly for a dumb question
The drive is about 76% full, and my question how can I overrode it so that storj can utilize more?
The included picture is of the original node of discussion:
Only to fix the usage on the dashboard, i.e. restart the node with the enabled scan on startup (which is enabled by default) and let it finish the scan and update the databases with a correct values.
However, if you would have errors, related to a databases and/or filewalkers, the used space would not be updated. So, you need to fix all errors related to the databases and/or filewalkers first.
Hey sorry for the delay.
So should I fix this, will this allow me to expand the storage past this limit?
Because I feel like the disk utilization is too low, I understand we need to keep a certain percentage in reserve but not almost 1/4 of the disk space
Also is there a guide or a place you can point me to, to know what the next steps are?
Thankyou
The allocation will always select between what’s you have provided and what’s available (as it thinks).
So, you need to fix issues with updating the databases with the actual values.
The next steps you can find there:
