I checked my node today and saw that since Oct 11 my node has not had any traffic from any satellites. The logs are giving me the satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted error and the dashboard says Status OFFLINE. The API also shows lastPinged: "0001-01-01T00:00:00Z" Restarting has not helped. I am on Node Version: v1.14.7.
Welcome to the forum @jshatch!
Can you show last 20 lines of the log ?
2020-10-21T00:08:55.726Z INFO Telemetry enabled
2020-10-21T00:08:55.745Z INFO db.migration Database Version {"version": 45}
2020-10-21T00:08:57.381Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2020-10-21T00:08:57.910Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
2020-10-21T00:08:57.911Z INFO bandwidth Performing bandwidth usage rollups
2020-10-21T00:08:57.911Z INFO trust Scheduling next refresh {"after": "7h24m54.50011038s"}
2020-10-21T00:08:57.911Z INFO Node 1Rz3kjsFTQ2yCVgRWqQWzG7C4Gt47mJdaUwHYMjW4zfh2fGdNV started
2020-10-21T00:08:57.912Z INFO Public server started on [::]:28967
2020-10-21T00:08:57.912Z INFO Private server started on 127.0.0.1:7778
2020-10-21T00:09:18.577Z WARN console:service unable to get Satellite URL {"Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "error": "storage node dashboard service error: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted", "errorVerbose": "storage node dashboard service error: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted\n\tstorj.io/storj/storagenode/trust.(*Pool).getInfo:228\n\tstorj.io/storj/storagenode/trust.(*Pool).GetNodeURL:167\n\tstorj.io/storj/storagenode/console.(*Service).GetDashboardData:160\n\tstorj.io/storj/storagenode/console/consoleapi.(*StorageNode).StorageNode:44\n\tnet/http.HandlerFunc.ServeHTTP:2042\n\tgithub.com/gorilla/mux.(*Router).ServeHTTP:210\n\tnet/http.serverHandler.ServeHTTP:2843\n\tnet/http.(*conn).serve:1925"}
2020-10-21T01:08:57.912Z INFO bandwidth Performing bandwidth usage rollups
2020-10-21T02:08:57.912Z INFO bandwidth Performing bandwidth usage rollups
2020-10-21T03:08:57.912Z INFO bandwidth Performing bandwidth usage rollups
2020-10-21T04:08:57.912Z INFO bandwidth Performing bandwidth usage rollups
2020-10-21T04:50:42.629Z WARN console:service unable to get Satellite URL {"Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "error": "storage node dashboard service error: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted", "errorVerbose": "storage node dashboard service error: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted\n\tstorj.io/storj/storagenode/trust.(*Pool).getInfo:228\n\tstorj.io/storj/storagenode/trust.(*Pool).GetNodeURL:167\n\tstorj.io/storj/storagenode/console.(*Service).GetDashboardData:160\n\tstorj.io/storj/storagenode/console/consoleapi.(*StorageNode).StorageNode:44\n\tnet/http.HandlerFunc.ServeHTTP:2042\n\tgithub.com/gorilla/mux.(*Router).ServeHTTP:210\n\tnet/http.serverHandler.ServeHTTP:2843\n\tnet/http.(*conn).serve:1925"}
2020-10-21T05:01:50.549Z WARN console:service unable to get Satellite URL {"Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "error": "storage node dashboard service error: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted", "errorVerbose": "storage node dashboard service error: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted\n\tstorj.io/storj/storagenode/trust.(*Pool).getInfo:228\n\tstorj.io/storj/storagenode/trust.(*Pool).GetNodeURL:167\n\tstorj.io/storj/storagenode/console.(*Service).GetDashboardData:160\n\tstorj.io/storj/storagenode/console/consoleapi.(*StorageNode).StorageNode:44\n\tnet/http.HandlerFunc.ServeHTTP:2042\n\tgithub.com/gorilla/mux.(*Router).ServeHTTP:210\n\tnet/http.serverHandler.ServeHTTP:2843\n\tnet/http.(*conn).serve:1925"}
2020-10-21T05:08:57.912Z INFO bandwidth Performing bandwidth usage rollups
2020-10-21T05:29:43.749Z WARN console:service unable to get Satellite URL {"Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "error": "storage node dashboard service error: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted", "errorVerbose": "storage node dashboard service error: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted\n\tstorj.io/storj/storagenode/trust.(*Pool).getInfo:228\n\tstorj.io/storj/storagenode/trust.(*Pool).GetNodeURL:167\n\tstorj.io/storj/storagenode/console.(*Service).GetDashboardData:160\n\tstorj.io/storj/storagenode/console/consoleapi.(*StorageNode).StorageNode:44\n\tnet/http.HandlerFunc.ServeHTTP:2042\n\tgithub.com/gorilla/mux.(*Router).ServeHTTP:210\n\tnet/http.serverHandler.ServeHTTP:2843\n\tnet/http.(*conn).serve:1925"}
2020-10-21T05:29:57.144Z WARN console:service unable to get Satellite URL {"Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "error": "storage node dashboard service error: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted", "errorVerbose": "storage node dashboard service error: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted\n\tstorj.io/storj/storagenode/trust.(*Pool).getInfo:228\n\tstorj.io/storj/storagenode/trust.(*Pool).GetNodeURL:167\n\tstorj.io/storj/storagenode/console.(*Service).GetDashboardData:160\n\tstorj.io/storj/storagenode/console/consoleapi.(*StorageNode).StorageNode:44\n\tnet/http.HandlerFunc.ServeHTTP:2042\n\tgithub.com/gorilla/mux.(*Router).ServeHTTP:210\n\tnet/http.serverHandler.ServeHTTP:2843\n\tnet/http.(*conn).serve:1925"}
2020-10-21T05:29:59.456Z WARN console:service unable to get Satellite URL {"Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "error": "storage node dashboard service error: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted", "errorVerbose": "storage node dashboard service error: trust: satellite \"118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW\" is untrusted\n\tstorj.io/storj/storagenode/trust.(*Pool).getInfo:228\n\tstorj.io/storj/storagenode/trust.(*Pool).GetNodeURL:167\n\tstorj.io/storj/storagenode/console.(*Service).GetDashboardData:160\n\tstorj.io/storj/storagenode/console/consoleapi.(*StorageNode).StorageNode:44\n\tnet/http.HandlerFunc.ServeHTTP:2042\n\tgithub.com/gorilla/mux.(*Router).ServeHTTP:210\n\tnet/http.serverHandler.ServeHTTP:2843\n\tnet/http.(*conn).serve:1925"}
Not sure if that’s going to show up or not, if it doesn’t I’ll re-post it.
Doesn’t look like it’s going to show up, here are the logs again, if it does end up posting twice, I’m sorry.
Check the steps mentioned in this post and let us know.
Everything looks good connectivity wise, and nothing has changed in the identity files since I generated them. This seems to have started around the time the node was upgraded by watchtower the last time.
time="2020-10-12T18:04:31Z" level=info msg="Found new storjlabs/storagenode:beta image (sha256:201fdc631ccb974bf57a49b5ef8093de54f09a0d9d93ced4ccf524934f2137ff)"
If that was true then your node wouldn’t be offline. There are occasions when things break without our interference hence its advisable to recheck things, hence the checklist.
Are you using DDNS or static IP ?
I figured it out. Somehow Cloudflare got configured to proxy my traffic to that DNS name. Fixed.
change
storjlabs/storagenode:latest
