Storage node offline
I just created my code and it stays off!
1574968041-capture.png - envoi d'image avec NoelShack
Welcome to the the forum! @MrGeekk
Here are a list of things you can try. :slight_smile:
Make sure:
~You are properly port forwarded.
~Have your DUC running.
~Your time PROPERLY synced.
~Try restarting the Service if you are on windows
~Make sure your local IP that you forwarded did not change (set your ip to static)
Also, you can post photos directly on the forum!
Hello @MrGeekk,
Please, go through this checklist:
Problème réglée . J’avais juste mal renseigner l’ip de “NO-IP” je l’ai modifier est tout est revenue dans l’ordre .
Merci
