Since the update to 1.6.4 I see the following error every now and then
The node crashes, sometimes it is able to restart itself, sometimes i need to restart the server
My node has been running perfectly for more than a year. Anyone knows what is wrong?
  github.com/spf13/cobra.(*Command).ExecuteC(0x19af1e0, 0xc0000ba100, 0x1137e68, 0x1)
        /go/pkg/mod/github.com/spf13/cobra@v0.0.6/command.go:945 +0x317
github.com/spf13/cobra.(*Command).Execute(...)
        /go/pkg/mod/github.com/spf13/cobra@v0.0.6/command.go:885
storj.io/private/process.ExecWithCustomConfig(0x19af1e0, 0x0, 0x1137e68)
        /go/pkg/mod/storj.io/private@v0.0.0-20200504130741-565a173f6d33/process/exec_conf.go:88 +0x192
storj.io/private/process.ExecCustomDebug(...)
        /go/pkg/mod/storj.io/private@v0.0.0-20200504130741-565a173f6d33/process/exec_conf.go:70
main.main()
        /go/src/storj.io/storj/cmd/storagenode/main.go:320 +0x3e
2020-07-20T16:50:11.666Z        INFO    Configuration loaded    {"Location": "/app/config/config.yaml"}
2020-07-20T16:50:11.678Z        INFO    Operator email  {"Address": "postema.ej@gmail.com"}
2020-07-20T16:50:11.678Z        INFO    Operator wallet {"Address": "0x688040253Ae127519B14a5fcB7FeaB56eF15EFd1"}
panic: runtime error: invalid memory address or nil pointer dereference [recovered]
[signal SIGSEGV: segmentation violation code=0x1 addr=0x28 pc=0xd42bfd]
goroutine 1 [running]:
github.com/spacemonkeygo/monkit/v3.newSpan.func1(0xc0003f7580)
        /go/pkg/mod/github.com/spacemonkeygo/monkit/v3@v3.0.7-0.20200515175308-072401d8c752/ctx.go:147 +0x3a8
panic(0xf6ef80, 0x19a3180)
        /usr/local/go/src/runtime/panic.go:679 +0x1b2
storj.io/storj/storagenode/storagenodedb.(*DB).closeDatabase(0xc00045c0f0, 0x10e7d39, 0x7, 0x19a3760, 0x3)
        /go/src/storj.io/storj/storagenode/storagenodedb/database.go:395 +0x7d
storj.io/storj/storagenode/storagenodedb.(*DB).closeDatabases(0xc00045c0f0, 0x10e401f, 0x4)
        /go/src/storj.io/storj/storagenode/storagenodedb/database.go:384 +0xae
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases(0xc00045c0f0, 0xc00045c0f0, 0x10e7d39)
        /go/src/storj.io/storj/storagenode/storagenodedb/database.go:187 +0x98d
storj.io/storj/storagenode/storagenodedb.New(0xc0004422a0, 0xc0003f5060, 0xe, 0xc000434f80, 0x1c, 0xc000434fc0, 0x16, 0x0, 0x0, 0xc0003f5060, ...)
        /go/src/storj.io/storj/storagenode/storagenodedb/database.go:172 +0x859
main.cmdRun(0x19af480, 0xc0001c5ce0, 0x0, 0xb, 0x0, 0x0)
        /go/src/storj.io/storj/cmd/storagenode/main.go:147 +0x5c6
storj.io/private/process.cleanup.func1.4(0x1288fa0, 0xc00045b0e0)
        /go/pkg/mod/storj.io/private@v0.0.0-20200504130741-565a173f6d33/process/exec_conf.go:359 +0x13b
storj.io/private/process.cleanup.func1(0x19af480, 0xc0001c5ce0, 0x0, 0xb, 0x0, 0x0)
        /go/pkg/mod/storj.io/private@v0.0.0-20200504130741-565a173f6d33/process/exec_conf.go:377 +0x21c2
github.com/spf13/cobra.(*Command).execute(0x19af480, 0xc0001c5c30, 0xb, 0xb, 0x19af480, 0xc0001c5c30)
        /go/pkg/mod/github.com/spf13/cobra@v0.0.6/command.go:840 +0x460
github.com/spf13/cobra.(*Command).ExecuteC(0x19af1e0, 0xc000084100, 0x1137e68, 0x1)
main.main()
2020-07-20T16:51:12.377Z        INFO    Configuration loaded    {"Location": "/app/config/config.yaml"}
2020-07-20T16:51:12.391Z        INFO    Operator email  {"Address": "postema.ej@gmail.com"}
2020-07-20T16:51:12.391Z        INFO    Operator wallet {"Address": "0x688040253Ae127519B14a5fcB7FeaB56eF15EFd1"}
github.com/spacemonkeygo/monkit/v3.newSpan.func1(0xc0003ef820)
storj.io/storj/storagenode/storagenodedb.(*DB).closeDatabase(0xc0004540f0, 0x10eab1e, 0xa, 0x19a3760, 0x3)
storj.io/storj/storagenode/storagenodedb.(*DB).closeDatabases(0xc0004540f0, 0x10e401f, 0x4)
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases(0xc0004540f0, 0xc0004540f0, 0x10e7d39)
storj.io/storj/storagenode/storagenodedb.New(0xc0000c2d80, 0xc0003ed0a0, 0xe, 0xc00042efa0, 0x1c, 0xc00042efc0, 0x16, 0x0, 0x0, 0xc0003ed0a0, ...)
main.cmdRun(0x19af480, 0xc0001bfc30, 0x0, 0xb, 0x0, 0x0)
storj.io/private/process.cleanup.func1.4(0x1288fa0, 0xc0004530e0)
storj.io/private/process.cleanup.func1(0x19af480, 0xc0001bfc30, 0x0, 0xb, 0x0, 0x0)
github.com/spf13/cobra.(*Command).execute(0x19af480, 0xc0001bfb80, 0xb, 0xb, 0x19af480, 0xc0001bfb80)
github.com/spf13/cobra.(*Command).ExecuteC(0x19af1e0, 0xc0000c2100, 0x1137e68, 0x1)
main.main()
2020-07-20T16:52:13.099Z        INFO    Configuration loaded    {"Location": "/app/config/config.yaml"}
2020-07-20T16:52:13.114Z        INFO    Operator email  {"Address": "postema.ej@gmail.com"}
2020-07-20T16:52:13.114Z        INFO    Operator wallet {"Address": "0x688040253Ae127519B14a5fcB7FeaB56eF15EFd1"}
github.com/spacemonkeygo/monkit/v3.newSpan.func1(0xc0003d5540)
storj.io/storj/storagenode/storagenodedb.(*DB).closeDatabase(0xc0004480f0, 0x10e401f, 0x4, 0x19a3760, 0x3)
storj.io/storj/storagenode/storagenodedb.(*DB).closeDatabases(0xc0004480f0, 0x10e401f, 0x4)
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases(0xc0004480f0, 0xc0004480f0, 0x10e7d39)
storj.io/storj/storagenode/storagenodedb.New(0xc00048d080, 0xc0003d3050, 0xe, 0xc000413360, 0x1c, 0xc000413380, 0x16, 0x0, 0x0, 0xc0003d3050, ...)
main.cmdRun(0x19af480, 0xc00019bc30, 0x0, 0xb, 0x0, 0x0)
storj.io/private/process.cleanup.func1.4(0x1288fa0, 0xc0004450e0)
storj.io/private/process.cleanup.func1(0x19af480, 0xc00019bc30, 0x0, 0xb, 0x0, 0x0)
github.com/spf13/cobra.(*Command).execute(0x19af480, 0xc00019bb80, 0xb, 0xb, 0x19af480, 0xc00019bb80)
github.com/spf13/cobra.(*Command).ExecuteC(0x19af1e0, 0xc00007c100, 0x1137e68, 0x1)
main.main()
2020-07-20T16:53:13.866Z        INFO    Configuration loaded    {"Location": "/app/config/config.yaml"}
2020-07-20T16:53:13.880Z        INFO    Operator email  {"Address": "postema.ej@gmail.com"}
2020-07-20T16:53:13.880Z        INFO    Operator wallet {"Address": "0x688040253Ae127519B14a5fcB7FeaB56eF15EFd1"}
github.com/spacemonkeygo/monkit/v3.newSpan.func1(0xc0003f77d0)
storj.io/storj/storagenode/storagenodedb.(*DB).closeDatabase(0xc0004580f0, 0x10ed56c, 0xd, 0x19a3760, 0x3)
storj.io/storj/storagenode/storagenodedb.(*DB).closeDatabases(0xc0004580f0, 0x10e401f, 0x4)
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases(0xc0004580f0, 0xc0004580f0, 0x10e7d39)
storj.io/storj/storagenode/storagenodedb.New(0xc000114ba0, 0xc0003f50d0, 0xe, 0xc000432fa0, 0x1c, 0xc000432fe0, 0x16, 0x0, 0x0, 0xc0003f50d0, ...)
main.cmdRun(0x19af480, 0xc0001c1d90, 0x0, 0xb, 0x0, 0x0)
storj.io/private/process.cleanup.func1.4(0x1288fa0, 0xc0004570e0)
storj.io/private/process.cleanup.func1(0x19af480, 0xc0001c1d90, 0x0, 0xb, 0x0, 0x0)
github.com/spf13/cobra.(*Command).execute(0x19af480, 0xc0001c1ce0, 0xb, 0xb, 0x19af480, 0xc0001c1ce0)
main.main()
2020-07-20T16:54:14.559Z        INFO    Configuration loaded    {"Location": "/app/config/config.yaml"}
2020-07-20T16:54:14.572Z        INFO    Operator email  {"Address": "postema.ej@gmail.com"}
2020-07-20T16:54:14.572Z        INFO    Operator wallet {"Address": "0x688040253Ae127519B14a5fcB7FeaB56eF15EFd1"}
github.com/spacemonkeygo/monkit/v3.newSpan.func1(0xc0003bb650)
storj.io/storj/storagenode/storagenodedb.(*DB).closeDatabase(0xc00042e0f0, 0x10e401f, 0x4, 0x19a3760, 0x3)
storj.io/storj/storagenode/storagenodedb.(*DB).closeDatabases(0xc00042e0f0, 0x10e401f, 0x4)
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases(0xc00042e0f0, 0xc00042e0f0, 0x10e7d39)
storj.io/storj/storagenode/storagenodedb.New(0xc0003882a0, 0xc0003b90a0, 0xe, 0xc0003ef140, 0x1c, 0xc0003ef180, 0x16, 0x0, 0x0, 0xc0003b90a0, ...)
main.cmdRun(0x19af480, 0xc000187c30, 0x0, 0xb, 0x0, 0x0)
storj.io/private/process.cleanup.func1.4(0x1288fa0, 0xc00042d040)
storj.io/private/process.cleanup.func1(0x19af480, 0xc000187c30, 0x0, 0xb, 0x0, 0x0)
github.com/spf13/cobra.(*Command).execute(0x19af480, 0xc000187b80, 0xb, 0xb, 0x19af480, 0xc000187b80)
main.main()
