Storagenode: Detected aborted journal
I’m a little unsure why this is appearing in the logs, and the disk occasionally going into RO…
I can’t see any issues with the disk as such
it might be since the latest version v1.121.2… but i can’t confirm that
Have you stopped the node, unmounted the filesystem, and “fsck -y”'d it?
i will do that in a little script to remount / restart storj on completion
It’s not related to storagenode and any its versions, something is wrong with the disk or its power supply or cables, it may be also result of problems with RAM. I would suggest to check the memory too.
