Error response from daemon: Container 5b17de42f5bdc73feab736eed95d71118ead34ed197301b2150ed697dad9a346 is restarting, wait until the container is running
Docker logs somehow look weird as well:
Error: read config/config.yaml: input/output error
Usage:
/app/storagenode run [flags]
Please, stop the container docker stop -t 300 storagenode and remove the container docker rm storagenode and run it back with all your parameters but with sudo.
Or chown the whole mountpoint recursively to your user pi and then you can run the container without a sudo.
What is your choice?
Then the chown should work.
After that sudo mount -a should mount your drive back.
After that you should be able to replace owner recursively for all other folders and files.
Looks like a problem with USB controller as well. Maybe it need an extra power from the external source.
I can suggest to use case, board and power supply from this vendor: https://geekworm.com/
might be the case. still weird it was working properly for weeks and suddenly âbrokeâ. just a pity it ruined my uptime for this month, meaning no payout in October!
I will have a look into the geekworm products though, thanks for sharing!
