Установил линукс, сделал ключ, привязал ноду к емейлу. На докере возникла проблема. Дашбоард показывает, но все время пишет offline в статусе ноды.
Вот логи:
root@m4f1Storj:~# docker logs --tail 20 storagenode
2020-03-31T23:00:28.996Z INFO bandwidth Performing bandwidth usage rollups
2020-03-31T23:00:28.997Z INFO Node номер ноды started
2020-03-31T23:00:28.997Z INFO Public server started on [::]:28967
2020-03-31T23:00:28.998Z INFO Private server started on 127.0.0.1:7778
2020-03-31T23:00:28.999Z INFO trust Scheduling next refresh {“after”: “4h44m55.183905977s”}
2020-03-31T23:00:29.295Z INFO version running on version v1.0.1
2020-03-31T23:10:50.710Z INFO Got a signal from the OS: “terminated”
2020-03-31T23:10:53.776Z INFO Configuration loaded from: /app/config/config.yaml
2020-03-31T23:10:53.830Z INFO Operator email: мыло
2020-03-31T23:10:53.830Z INFO operator wallet: кошелек
2020-03-31T23:10:54.666Z INFO version running on version v1.0.1
2020-03-31T23:10:54.694Z INFO db.migration Database Version {“version”: 33}
2020-03-31T23:10:56.144Z INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-03-31T23:10:57.087Z INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-03-31T23:10:57.087Z INFO bandwidth Performing bandwidth usage rollups
2020-03-31T23:10:57.089Z INFO Node номер ноды started
2020-03-31T23:10:57.089Z INFO Public server started on [::]:28967
2020-03-31T23:10:57.089Z INFO Private server started on 127.0.0.1:7778
2020-03-31T23:10:57.090Z INFO trust Scheduling next refresh {“after”: “8h33m41.16087346s”}
2020-03-31T23:10:57.390Z INFO version running on version v1.0.1
Вот еще, дабы не было вопросов про сертификаты:
root@m4f1Storj:~# docker exec -it storagenode ls -l /app/identity
total 24
-rw-r–r-- 1 root root 514 Mar 31 18:47 ca.1585680455.cert
-rw-r–r-- 1 root root 1044 Mar 31 18:47 ca.cert
-rw------- 1 root root 241 Mar 31 17:09 ca.key
-rw-r–r-- 1 root root 1056 Mar 31 18:47 identity.1585680455.cert
-rw-r–r-- 1 root root 1586 Mar 31 18:47 identity.cert
-rw------- 1 root root 241 Mar 31 17:09 identity.key
Что еще нужно для Аудита? Прошу помощи.
