Storagenode on my Rpi4 is 'OFFLINE' after about 4 hours of working
Hi all,
I’m new user and I followed the tutorial to use my external HDD to my Rpi4.
All gone fine but this morning I was ‘Offline’. I checked all the part (port fowarding, ufw, noip) and everything was OK. So I stopped the docker storagenode, I removed it and I installed it again without any difficulty.
Few minutes ago (after about 4 hours of well working), it stopped again.
I just done the same steps but I’m still ‘Offline’.
Do you have any idea what’s going on ?
Many thanks! :wink:
Aurel
Hello @aurelb87 and welcome to the forum :slight_smile:
Is there anything of interest in the logs?
Also, maybe some useful guidances there:
Hello Pac,
Thanks for your answer and also for your welcome! :slight_smile:
Well, I have checked it (guidances) before to post my message but all was fine.
Few minutes after my post, I did ‘stop’, ‘rm’ and run again the storagenode docker and finally I succeeded to be ‘Online’.
Regarding the logs file, I have checked it but I don’t remember all the fine…
I just remember that I had the message “Failed to sufficiently increase receive buffer size” so I fixed it with : sysctl -w net.core.rmem_max=2500000 (many thanks to the forum :wink: ).
I keep in touch during the next hours in order to see if I have the same problem… (And save the logs file… :wink: )
Aurel
Alright, cool ^^
If you haven’t done it already, you can redirect logs to a file so they don’t disappear each time you restart your node:
That’s a good practice :wink:
Thanks Pac for your advice! :+1:
Very useful! :slight_smile:
